Main > Main Forum
fan for arcade
Pages: << < (3/3)
Caparo8bit:
--- Quote from: GoYouSalukis on August 08, 2013, 11:07:48 pm ---The fan in your last photo says 12VDC, so yes you can connect it to 12 volts. the direction is controlled by which way you connect the wires. If it is blowing the wrong way, just reverse the wires.
thanks question fan for arcade amp is blowing out shold i put second fan blowing in
GoYouSalukis:
I would set it to blow in so that you get a positive airflow through the case.
yotsuya:
--- Quote from: Caparo8bit on August 08, 2013, 11:08:32 pm ---
--- Quote from: yotsuya on August 08, 2013, 11:05:13 pm ---Hey, is it me, or does that fan look like power supply?
i gues its you
 :lol
Drnick:
--- Quote from: Caparo8bit on August 08, 2013, 11:15:26 pm ---
Set the one at the bottom to blow air into the cabinet (Will probably want reversing from existing) and then set the one you have higher up to suck air out of the cabinet.   Warm air rises so this would be the most effective. I would recommend a dust filter for the one blowing air into the cab.
Malenko:
--- Quote from: Caparo8bit on August 08, 2013, 10:57:04 pm ---ok my arcade has a fan and two extra power ports available can i connect second fan on those ports (secon fan is for cpu) chec pics please
"And I know the im going for the Noob of the year"
DONT TOUCH THOSE.
Thats the AC line in , its fused from the power cord to the power supply. If you want to tap 12v, tap it off the power supply where it is clearly labeled +12v. Honestly if you're putting a PC in there I'd just get another PC fan and tap it off the PC power supply.
Pages: << < (3/3)
Go to full version
