Author Topic: Mini arcade controls?  (Read 1363 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
« on: August 07, 2013, 12:29:26 pm »
Hi where do you buy mini arcade controls
UFO
  • Last login:July 22, 2022, 06:37:12 pm
  • Im nearly out of unproductive things to do at work
Re: Mini arcade controls?
« Reply #1 on: August 07, 2013, 12:47:11 pm »
Depends how mini really.
I'm building a 3/4 size cab that I use standard controls in, but on here I have seen all sizes in-between up to a Nintendo DS screen with tiny controls.
Can you be more specific?
ark_ader
  • I glow in the dark.
« Reply #2 on: August 07, 2013, 01:44:04 pm »
Go to http://www.arcadeshop.de/index.php?language=en
I got a small 4 way and small buttons for my sub mini.
Top class service too.  Have a look at groovygamegear.com too.
Unless we are talking dinky then maybe cpc
Darren01274
« Reply #3 on: August 07, 2013, 02:53:39 pm »
the cab needs to fit around a 4.3" screen so the controls are gonna need to be kinda small, any recommendations much appreciated.
  • Last login:Today at 12:28:31 pm
« Reply #4 on: August 07, 2013, 03:22:35 pm »
Grayhill battop from Allied Electronics.  Other suppliers like Mouser carry it too, IIRC.  This is what Bender used in his micro DK and Le Chuck is using in his micro Gauntlet.
These Grayhill joysticks have a .850" square base.  Datasheet here.
BTW you don't need to solder on the Grayhill joystick pins. The joystick pins fit snugly into .100" header sockets like this or this.  The spacing is wrong to fit more than one pin to a connector, but 5 individual connections works great.  These box-style socket pins can be easily removed from the connector body.
CAUTION:  The joystick pins aren't quite long enough to work properly with the commonly used ramp-style KK100-type contacts like this.
  • Last login:May 05, 2024, 08:59:50 am
« Reply #5 on: August 07, 2013, 04:16:22 pm »
Are you going for a replica with controls sized accordingly or playability?
How many buttons? (if only a couple, you can use bigger ones for better playability)
What platform will the games be running on?
