Author Topic: new using j-pac (Solved)  (Read 1056 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: August 06, 2013, 02:44:27 pm »
hello there im using j-pac for my project (first project) with a laptop do i still need to connect a keyboard?
and how come j-pac vga is male no female i bought a vga male\male now i have to buy a adapter  :banghead:
thanks to you guys my project is almost done :notworthy:
« Last Edit: August 07, 2013, 02:25:45 am by Caparo8bit »
Caparo8bit
  • Hyperspin/Maximus
Re: new using j-pac
« Reply #1 on: August 06, 2013, 10:16:48 pm »
ok so now every time a connect the usb from the j-pac (PC KB/USB) in to my laptop usb  for some reason the computer starts tapping q569 q569 q569 and wont stop............. :angry:  help please
paigeoliver
  • Awesome face!
Re: new using j-pac
« Reply #2 on: August 06, 2013, 11:06:51 pm »
You probably have those inputs shorted in your arcade wiring.
  • Last login:Today at 12:28:31 pm
Re: new using j-pac
« Reply #3 on: August 06, 2013, 11:19:56 pm »
That or you have the wires hooked to the Normally Closed (NC) and common (COM) tabs on the microswitch instead of the Normally Open (NO) and COM tabs.
Caparo8bit
  • Hyperspin/Maximus
Re: new using j-pac
« Reply #4 on: August 07, 2013, 12:56:23 am »
dude you are the best  :applaud:...ground cable was on ( NO) and and 2nd cable was on (com) :notworthy: :notworthy: :notworthy:
Caparo8bit
  • Hyperspin/Maximus
Re: new using j-pac
« Reply #5 on: August 07, 2013, 12:56:58 am »
yeah found them tysm
Re: new using j-pac
« Reply #6 on: August 07, 2013, 01:30:12 am »
Thank you.   :cheers:
Looks like you were using part of my "backward" wiring trick.
More on a similar, but larger-scale related wiring technique soon. . . . Right, Jon?   ;D
« Last Edit: August 07, 2013, 01:31:53 am by PL1 »
Caparo8bit
  • Hyperspin/Maximus
Re: new using j-pac
« Reply #7 on: August 07, 2013, 02:35:01 am »
Thank you.   :cheers:
......was like that. I bought it from a guy and idk if I over pay $200 is a show case 33" deluxe  snk vs stf  I'm taking arcade monitor out  cant make it work with my laptop ( widows 7  hd intel graphics) if you pay delivery monitor is all yours ... I'm planing to use LED 32" ( stretched picture) to get full screen . Lepai 2.1 amp. My next step is map c. Panel to Maximus arcade... Any idea how......?
Re: new using j-pac (Solved)
« Reply #8 on: August 07, 2013, 04:37:46 pm »
Are you sure you want to get rid of the monitor?
Instead of a laptop, you can use a cheap PC to get it up and running.
BTW, the thread offering the monitor for trade should be in the Buy/Sell/Trade forum.
Caparo8bit
  • Hyperspin/Maximus
« Reply #9 on: August 07, 2013, 07:48:51 pm »
  cheeeeeeeeezzzzzz  :o i just removed the monitor few mins ago and is heavy as helllllll.....!and yeah i have a 32" led sitting in the garage and i like how mame looks using hdmi from pc/led  . shiping must cost $$$$$$$$ lots...
