Main > Software Forum
HTML5 FrontEnd
arximidis:
[message deleted by me]
arximidis:
News
I have now added full mouse support. Even using the mouse wheel.
However because you must do too many changes to the code, I will upload the complete code soon
arximidis:
New Version 2.3
I have uploaded the new version of HTML FrontEnd
Added full mouse support.
Usage: All carousel pics are clickable. Click to load the game lists.
Scroll the carousel with the mouse wheel.
Clicking with the middle mouse button (sometimes this button is when you click the mouse wheel) enables search by the letter (same as Page down/page up). Roll the wheel to change letter.
link:http://users.ntua.gr/dpiperid/MyWebPage/Catalog/games/HTMLFrontEndEN.htm
Setup directions: http://users.ntua.gr/dpiperid/MyWebPage/Catalog/games/FE_tutor/htmlFEtutorEN.htm
arximidis:
New version 2.4
Added cookies support
Some bug fixes
In the FrontEnd I created a simple (for now) settings page based on cookies. You can set the paths of the roms, without interfering with the code. Also some other settings are added
[edit]
Version 2.4.1
1) Improved settings page
2) Now you can set up the emulators without interferring with the code.
3) Improvements to the main html code
arximidis:
--- Quote from: GoYouSalukis on August 20, 2013, 11:24:21 pm ---....
On the rotation issue, it seems I can rotate a canvas 90 degrees no problem. Is it perhaps possible to put the carousel in a canvas and then rotate it? Or is that too easy?
OK
The new version is comming... and you can rotate the whole thing 90 degress (CW or CCW). You can even rotate 180degrees, without even interfering with the code!
Comming soon...
Also I modified the code to add or remove emulators dynamically...
