Main > Software Forum
HTML5 FrontEnd
Pages: << < (43/46) > >>
Le Chuck:
Cool, so I'll just wait for that one then ::)
arximidis:
Ok it works
I will upload today the new qt version for you to try.
I have fixed only the sound and did nothing for the crashes when you load the emulator for the fisrt time
Fisrt check if background music stutters
If everything it's ok with the sound then I will check the code that loads the emulators too
One good thing with this approach is that we will have some sort of anti-crash feature (but I will not implement it right away)
arximidis:
New version uploaded (version 4.0 of HTMLFrontEndQT and 4.2 of default640x480 theme)
This is the first attempt to combine the two versions for windows. Why? Because the majority of cabs (including mine) use Windows XP as operating system
This version requires... everything
VLC (full install)
Windows media player (pre-installed on Windows XP)
If you use a "weird" codec for your mp3's then k-lite codec pack is a good choice to install
Internet explorer (pre-installed on Windows XP)
EDIT:
I Fixed a minor bug to the theme.   :banghead:
I have re-uploaded
Le Chuck:
It works! Full speed audio and starfield with no hiccups on WXP64. Very nice, now if you can address that crash issue we will be straight. Nicely done.
Crash issue has started to pop up on executables other than just mame as well. Looking forward to not having to worry about that.
arximidis:
Good Day Le Chuck!
It is possible today to upload a new version in order to correct this problem (As always I have an idea for you to try :) It looks like this combination thing actually works )
However I am not sure... I will inform you when this happens
Go to full version
