Main > Software Forum
HTML5 FrontEnd
Pages: << < (34/46) > >>
nitrogen_widget:
--- Quote from: arximidis on April 07, 2014, 11:35:10 am ---I have build and uploaded the 32bit version for linux too. I haven't tested it yet. Only the 64bit on a Linux Mint distro.
If you test it, let me know if you encounter any problems
Thank you
I will try to test it tonight after the kids go to bed.
Thanks.
Ok, on two different linux installs the startup lightening animation runs then it either sits there with a grey screen or just closes.
I gotta be missing something.
arximidis:
--- Quote from: nitrogen_widget on April 07, 2014, 12:00:44 pm ---Ok, on two different linux installs the startup lightening animation runs then it either sits there with a grey screen or just closes.
That means it doesn't run the html5 video tag. It's not supporting it. In the Linux versions I have removed vlc plugin. Maybe it's time to bring it back
You can try the 64bit version on Liux Mint 16 for example, which I used for testing
arximidis:
Great News
I managed to fix the crashes on the QT version.
The reason I am still working on QT version is because it runs normally on windows XP.
The IE version instead requires a version of windows where you can install IE9+ (meaning vista or higher)
The QT version still requires vlc to be installed and it works on Linux too
I will upload the new version 3.1, soon
Le Chuck:
That's great news, my cab for this FE is winXP, didn't even realize this would have been an issue. Good deal  :cheers:
nitrogen_widget:
--- Quote from: arximidis on April 13, 2014, 01:48:37 pm ---Great News
so this will now work on 32 bit linux?
I was going to try it on 64 bit tonight.
Go to full version
