Main > Main Forum
hang on - accelerator cable needed
Pages: << < (3/3)
Le Chuck:
Without knowing exactly what unit you have it'd be hard to say for sure but my SHO frame has gobs of grease seemingly everywhere on it, so yeah, if it's been stripped it could probably due with some lube.
tony.silveira:
was about o edit my post, found the issue.  during the re-assemble, i had two left over washers which i found where they go, over the two main posts inside the unit.  this keeps the inside from grinding.
stupid me, all good!
jennifer:
    If you dissassembled that thing, painted it and put it back together (only forgetting 2 washers) I am totally impressed... That is a very complex cp, Basicly 3 spring loaded plates all working together.
tony.silveira:
sorta impressed myself even but thanks for the kind words.  i *just finished my proof of concept with the hang-on controller, check the link in my sig for an update to my cab.
slyskyspy:
Hi! I have the same issue with my accelerator cable broken on a Super Hang on cab. How did you fix it?
Many thanks!
Alex
--- Quote from: tony.silveira on August 04, 2013, 03:23:28 pm ---i just did it and you're right, painfully simple.  my accelerator works beautifully now, thank you both for your input.
i am having an issue with the left right though and i can not figure it out.  i completely disassembled the controller to clean and paint it.  after putting it back together, turning left/right is "sticky", meaning it isn't very smooth.  if i loosen the two main bolts that hold it together it turns easier but i don't remember those bolts being loose when i first took it apart.
can anyone confirm is there was some grease in there to help the left/right movement that maybe i removed when i cleaned it up?
thanks again lechuck,
tony
Pages: << < (3/3)
Go to full version
