Main > Project Announcements
NES bartop with stand [done]
<< < (35/35)
BlueGhost:
Very clean, but I can't help thinking of this when I see the pedestal.
edekoning:
Got two layers of white primer done. Now I am wondering what color I should paint the base. Should I go with the same overall light grey from the bartop, or the medium grey from the front of the control panel? I think going with the darker grey makes the bartop itself stand out more. Whereas the lighter grey will make it more a single piece.
yamatetsu:
Or maybe option 3? Medium grey on the front, light grey on the sides. Makes it even more cohesive.
edekoning:
--- Quote from: yamatetsu on October 20, 2022, 01:36:41 am ---Or maybe option 3? Medium grey on the front, light grey on the sides. Makes it even more cohesive.
That is a great idea ... until I went buying paint ... 40 bucks for 0.5 liter ... so Instead went with light grey.
I found this nifty website where you can convert from RGB to nearest color standards. Including RAL which is a common paint color standard here. So I used that to convert from my side art to a pretty spot on paint color!
https://www.e-paint.co.uk/convert-rgb.asp
Anyway here are the results. Note hat I put the Bartop against the wall, which made it really stable. Quite happy with the results 8)
leapinlew:
Good clean job!
You could add another base under that base, and make it bigger all the way around if it just needs a little more stability.
Navigation
Message Index
Previous page
Go to full version
