Main > Main Forum
High Score Competition #121 Qix
Vigo:
--- Quote from: JDFan on July 31, 2013, 07:19:47 pm ---(you get double points for using slow speed)
Never knew that! :)
mimic:
Which rom are you guys using? Comtek didn't post any dip switch settings or rom name. Are you using qix set1, 2 or 3?
epetti:
--- Quote from: mimic on July 31, 2013, 09:40:01 pm ---Which rom are you guys using? Comtek didn't post any dip switch settings or rom name. Are you using qix set1, 2 or 3?
I was just using the one named qix.zip which I believe is set 1, with default settings.
mimic:
I got some odd problem. Qix started just fine, but after I exited and tried to go back, it flashes for a split second some kind of mame message and then goes black and it looks like it's out of range (the monitor doesn't say it, it's just turns off the screen) I didn't adjust anything.
49,044 after second game, but I can't get back in.
JDFan:
Must be a bit rusty ! 57,476 was the best I could get this evening.
