Author Topic: arcade speakers SOS (solved)  (Read 1642 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: July 28, 2013, 01:59:36 pm »
my showcase 33" deluxe have  3 speakers two on top and one bottom im using j-pac cus im using the original control panel btw i switched arcade monitor for led 32" so now the question is how do i wire the speakers in to my pc?? this arcade comes with this (pic) only change audio from one spk to other ..can i used for volume up/down????
"ima noob and sorry for my spanglish"
« Last Edit: August 08, 2013, 11:26:07 pm by Caparo8bit »
Caparo8bit
  • Hyperspin/Maximus
Re: arcade speakers SOS
« Reply #1 on: July 29, 2013, 05:40:51 pm »
help????? i found out the we can use a mini amp (motorcycle) any brands or ideas please.......
« Last Edit: July 29, 2013, 05:44:01 pm by Caparo8bit »
keilmillerjr
  • Web Developer.
« Reply #2 on: July 29, 2013, 09:32:25 pm »
Does the cabinet have a separate audio amplifier? It's hard to tell from your pictures. That switch changing audio from one speaker to another makes no sense. I can't see why you would want that. What arcade machine do you have? Maybe some one can chime in if they are familiar with it. Maybe take off the back panel and get a rear shot of that unit.
Caparo8bit
  • Hyperspin/Maximus
« Reply #3 on: July 29, 2013, 11:13:22 pm »
I have a showcase 33" deluxe with street fighter vs snk ( Jamma)  j- Pac is on his way and I'm using led 32" so I want to connect the arcade speakers to my pc ..and thanks for your help
Caparo8bit
  • Hyperspin/Maximus
« Reply #4 on: August 01, 2013, 08:20:37 pm »
so is there a way to use arcade speakers in my project:
ima b using j-pac and LED 32" if arcade monitor dont work with pc
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #5 on: August 02, 2013, 09:33:08 am »
You'll have to chase down the wiring harness to figure out what goes where. It doesn't look like that unit has a seperate audio amplifier, which is part of the problem.
You'll need to wire in a seperate amplifier, be it a Car unit with an external PSU, or a home unit. Run your JAMMA harness audio lines to the amplifier (you'll probably need to make your own adapters) and take the amplified outputs and run those to your speakers (this is why you'll be chasing the wiring around).
Probably ~1hr worth of work, tops.
Caparo8bit
  • Hyperspin/Maximus
« Reply #6 on: August 02, 2013, 10:39:24 pm »
thanks ima re-wire the speakers and getting a 2.1 amp :cheers:
keilmillerjr
  • Web Developer.
« Reply #7 on: August 03, 2013, 01:48:00 am »
I got the lepai 2020+ amp as recommended by other members here. You don't need something fancy for arcade sound. Phew phew woosh boing pin doink. Haha!
Caparo8bit
  • Hyperspin/Maximus
« Reply #8 on: August 03, 2013, 03:18:34 pm »
thanks im using  lepai lp-838 2.1
« Last Edit: August 08, 2013, 11:26:49 pm by Caparo8bit »
ark_ader
  • I glow in the dark.
« Reply #9 on: August 03, 2013, 03:20:59 pm »
Obviously you haven't played reactor.
marioxb
  • Last login:March 08, 2024, 01:54:31 pm
« Reply #10 on: August 15, 2013, 01:23:19 pm »
So speaking of Reactor, and other games that I heard use a subwoofer, like MK.. Is there a way to wire up and amp/ sub to the cab speakers and have it work for a J-PAC AND regular Jamma boards at the same time, via a 6 in 1 Jamma switcher? I want to have a universal volume control that would control everything. My cab is a converted Tekken 2 that does not have any negative 5 volts or volume control or amp. Can I use a PC/ car whatever amp to bypass boards that use -5, like MK? Is the -5 ALWAYS only for the speaker amp/ volume?
Caparo8bit
  • Hyperspin/Maximus
« Reply #11 on: August 15, 2013, 01:29:45 pm »
this is what i did for $22 dlls speakers and woofer will go streigh in to the amp
« Last Edit: August 15, 2013, 01:31:18 pm by Caparo8bit »
marioxb
Re: arcade speakers SOS (solved)
« Reply #12 on: August 15, 2013, 07:11:01 pm »
That's pretty sweet! Does it work for regular Jamma boards too, or just PC?
Caparo8bit
  • Hyperspin/Maximus
« Reply #13 on: August 15, 2013, 07:21:07 pm »
i know there is a way to connect speakers and woofer in to jamma harnnes cus my shocase 33" deluxe was connected like that but the bad think ya can only control volume from pcb. Well im making mine MAME so what i did i disconnect all cables from behind of the speakers and woofer and i ran new ones to the amp and from the amp goes to the pc ( sorry for my spanglish)
Unstupid
« Reply #14 on: August 15, 2013, 07:40:44 pm »
You will have to check your board schematics and pick off the audio line level signal before it makes its way to the on-board amp.  If you can find the line level signals send those to the lepai amp....
« Last Edit: August 15, 2013, 07:42:28 pm by Unstupid »
