Main > Software Forum
MK9 controls in arcade cab.
<< < (2/3) > >>
BadMouth:
Also, there are 8 buttons to map, but two aren't necessary.
 Flip Stance can be accomplished by pressing Front Kick + Back Kick
 Throw can be accomplished by pressing Front Punch + Back Punch
Those two don't have to be mapped to your panel, but they must be mapped to something before the game will let you save and exit.
Just map some unused keyboard buttons to the rest of the xbox controller buttons in x360kb.ini and press those for Flip Stance and Throw.
The Mortal Kombat TE fight stick doesn't include these extra buttons.
It has the same layout as MK3 with Tag where the Run button was.
eds1275:
I played the hell out of that game, but never understood the opint for flipping the stance... anyone care to let me in on why you would ever do this?
Howard_Casto:
I think it's something that the devs started on but never really finished.
This game doesn't have hp/lp or hk/lk, it has left and right punches and kicks.  When you flip stance, those are reversed so you are hitting your opponent on the other side of their body.  In theory if there was a move that only blocked one side of a character you could flip stance and hit them with the other, but AFAIK all blocks/breakers/ect work on both sides.
The real reason is probably because on a 360 controller you press both stance and block to do an xray... they wanted the stance button to do, something when not used for an xray.  I thought it would have been cool to have the x-ray mapped to block + all punches and kicks.  Then to do an x-ray you hold down the "X" on the arcade panel.  ;)
The game has weird controls though.  Having to use the back button to access classic smoke is ridiculous.
TheManuel:
Someone from NetherRealms explained that in some game modes your character's limbs can be severed so you have to flip stance in order to perform a move that would required the severed limb.
Howard_Casto:
That's certainly true, but it seems odd to dedicate an entire button just for a couple of challenge mode matches (there are literally two that need this I think).
That is just more evidence to me that they had planned to do something with the mechanic, but never got around to it.
Navigation
Message Index
Next page
Previous page
Go to full version
