May 07, 2024, 02:31:11 pm
Sometimes a small flat head screwdriver can also be used to break the dot in the middle so a normal star bit or sometimes even a allen key can be used. That's only if you are really impatient like I am sometimes.
It's a "security torx". The easiest is to pick up one of these. Handy for all kinds of things. Just make sure it has the size you need.
