Main > Main Forum
Name that cab!
paigeoliver:
I really don't suggest getting into the various multiboards and kits until you have completed your first general mame cabinet. The multiboards generally involve serious compromise. They are great for filling out a gameroom or getting a cheap multicade going on an original monitor, but they generally pale in comparison to a full mame cabinet. In most cases you have to turn off a serious chunk of the games on the multiboard because they either don't run correctly or because the board mixes control types freely.
I have a few multis myself.
60 in 1 in a scratchbuilt cabaret (8-way and trackball games turned off).
138 in 1 in a Cliff Hanger cabinet (4-way and trackball games turned off).
19 in 1 in a converted poker cabaret (Defender, Stargate and 4-way games turned off).
jRok Multiwilliams in a Robotron cabinet.
161 in 1 Neo Geo in a dedicated Samurai Shodown II cabinet.
Space Invaders 8 in 1 multigame in a Midway Space Invaders upright.
Skivt68:
Just curious, how did the multigame neogeo cart work out? I may consider that an option as the pc I have may not be powerful enough to run some of the games I want to play. I think that maybe getting a 1 slot with a 160-in-1 would be a good option. Or is you could recommend some specs for a cheap pc? The games i really want to have are: Galaga, 1944, rest of the 19xx series if possible, donkey kong, mario bros, galaxian, and maybe dodonpachi. Also, some non mame emulators that I would like to include are, a neogeo emulator, and possibly a naomi/dreamcast emulator unless I shell out for a dimm board and CF reader to use on the one in the cab or buy a dreamcast to jamma adapter. What PC specs would run all of the games excluding the naomi emulator? Also, what specs would be good for all including the naomi/dreamcast emulator?
Malenko:
MAME runs all the neogeo games AFAIK and the requirements are quite low, Neogeo specific emulators have even lower requirements. I was playing NeoGeo games full speed way back in the P4 1.8 days if memory serves. There is also a fine line between asking for help and asking other to do your research, look up the naomi/dc emus and find out their specs and plan accordingly. Also, you are mixing a lot of vertical and horizontal games; are you planning to rotate the monitor or play with black bars?
Skivt68:
Thanks for the reply about the neogeo emulator requirements. I know I am mixing games quite a bit. This is all up in the air until I get the cab (in the process of setting up a time for me to inspect and haggling prices). I will be keeping the monitor in the horizontal position and playing vertical games with black bars. Sorry about asking for specs, I do know a fair bit about hardware from having built my custom pc last summer, but I was mainly just curious as to what other people are using, forgive my mistake earlier. I will be doing more research once I get some free time and can start specing-out the (possible) build. I was asking about a dedicated NeoGeo emulator because the build of mame I'm using (shmupmame 4.2, I love it) doesn't display my neogeo roms as having the rom file, yet when I run them from the gui manualy, they work fine. I will either have to figure out that issue, or just get the dedicated emulator.
paigeoliver:
Neo Geo ran full speed on a 500 mhz processor back in the mame .55 days. You will have no problems emulating it.
The Neo Geo multicarts can be flaky because some neo geo motherboards don't like them, and they sometimes have color issues with some games.
I have 3 one slot boards (a big US one, a big japanese one and a little US one). The little US one was very reset prone with the multicarts unless you let the attract mode run for a long time before you started the game (does it with both my multicarts). The big japanese one I have does the same thing with my 150 in 1 cart, but not with my 161 in 1 cart. While the big american one runs both multicarts just fine.
