Main > Main Forum
Atari cabaret plans?
spystyle:
I think plans can be made from Google Sketchup files.
If so, here are a bunch, starting with a Donkey Kong cabaret :
https://3dwarehouse.sketchup.com/model.html?id=14c80796f521c80533276a8c0b1c862
101 pages to sort through LOL
http://forums.arcade-museum.com/showthread.php?t=126766
We really need a "cabinet plans" forum here, a central location for all the plans made, found, or requested :)
PL1:
--- Quote from: spystyle on March 17, 2014, 07:00:41 pm ---We really need a "cabinet plans" forum here, a central location for all the plans made, found, or requested :)
There's already a wiki page for that here. ;D
TKW4rr10r:
--- Quote from: nitz on March 15, 2014, 11:42:24 pm ---I don't think we ever got plans per se, but if you check out Haruman's stickied bartop thread in the Buy/Sell/Trade forum, there were some pictures with measurements given that would probably give you enough info to build one as long as you're not hung up on it being perfect. ;)
Correct. I took measurements of a centipede cabaret that was badly water damaged and still plan to rebuild. But the plans made from that are a CNC style build that are not a true 100% replica, if you want to get technical. They are Haruman's plans in case you wanted to ask him directly nicely. Otherwise, my measurement photos of the original cab should still be in that thread a few pages back. If not I'll dig up the photos or can take whatever additional measurements you need. I haven't tossed the old cab yet.
I still plan to get mine CNC cut, but it shouldn't be hard to get a copy made from those measurements. The main difference in the centipede and tempest cabs are the additional venting for the color vector tube in the back, and the panel behind the marquee was used for a light fixture in tempest, but not in centipede.
spystyle:
I don't know how to use sketch-up or CAD or any of that. Is there a recommended crash course ? Or maybe someone would make plans from sketch-up files for a few bucks each ?
I found 6 sketch-up files I'd like to have as plans :)
404:
--- Quote from: spystyle on March 17, 2014, 07:00:41 pm ---I think plans can be made from Google Sketchup files.
the DK cabaret sketchup is not accurate. AT ALL.
