May 07, 2024, 03:06:25 pm
It will work with any joystick that uses microswitches.A switch is a switch is a switch, regardless of brand.
Quote from: BadMouth on May 20, 2013, 04:49:34 pmIt will work with any joystick that uses microswitches.A switch is a switch is a switch, regardless of brand.Ok, what I meant if harness like this (similar to the one found in x-arcade usb upgrade kit):http://www.gremlinsolutions.co.uk/products/daisychainharness.htmis directly pluggable in microswitches of Sanwa JLW.My doubt is due to some photos of Seimitsu LS32 (I know, it's a different product) where I see a single cable coming out from the pcbhttp://img.diytrade.com/cdimg/545775/11439113/0/1260872266/Seimitsu_Joystick_LS-32-02_LS-32.jpg
The other thing to remember is that there are several models of LS-32.The plain LS-32 uses regular microswitches.[cut]
