Main > Everything Else
Side Project - Beaker Muppet
<< < (7/7)
ChadTower:
Have you tried looking on Jammit?  More and more artists are releasing isolated tracks onto Jammit.  You might just find what you're looking for there without all the effort.
Howard_Casto:
It's a little late for this, but for Halloween props I use a talking boris skull.  The motor is really weak but what is nice about it is it has all these voice changer effects and if you set it to "robot"  it'll only respond to vocals in most musical pieces.  Of course I clip the speaker so you don't actually hear the robot voice and use the mp3 player to play the music via a splitter.
Your other option is to open up source-forge and manually make a track. Just like my boris, you would clip the dougie speaker and use your own on the right channel.  The left channel which you would use for mouth movement, could just have a series of tones.
I've done it that way before, but it's a colossal pain in the butt in terms of the amount of work you have to do.
ChadTower:
I've seen some of the props made from Boris skulls.  Cool stuff.  Too bad they're so hard to come by now.
mcseforsale:
subscribed...best thing I've seen today.
AJ
Vigo:
Thanks all!
I'm surprised that there isn't a good audio servo board out there. I see there is the scary terry kit, but that is about $50 after shipping. I' surprised nobody has released a simpler < $20 board. Thanks for the boris skull tip, I didn't know about them. I will keep my eyes peeled at the thrift stores.
--- Quote from: ChadTower on May 23, 2013, 03:27:19 pm ---Have you tried looking on Jammit?
Cool site, library is a bit weak but it looks to be growing. I'll keep my eyes on it.
--- Quote from: shrunkenmaster on May 23, 2013, 03:26:02 pm ---
--- Quote from: Vigo on May 23, 2013, 02:58:15 pm ---
 I just wish I knew how exactly to extract voice myself as I want him to be my main Christmas/Halloween prop and sing appropriate songs without any false triggers.
Only accurate way is using phase cancellation, but you'll need the 'vocal' version of the track (ie. the music AND the vocal), plus the instrumental. When they're both played at the same time with the phase of one inverted, then the similar frequencies are cancelled out, giving you the accapella, which you can then record. It's still hit and miss for a load of reasons though. Otherwise, super-harsh EQ is your best choice, but far from perfect! Loads of stuff online about this, just google 'accapella extraction' or similar. Hope that helps, great project!
Thanks! I'll try this method.
Of course, I probably can just record myself singing along to the song and sync that with the music. I would have to make sure that channel only gets routed through Beaker and remains unheard. I have an awful voice, and it makes me cringe just listening to myself sing. I don't know what effects it would have on others.
Navigation
[0] Message Index
[*] Previous page
Go to full version
