Author Topic: Hardware issue?  (Read 808 times)
keilmillerjr
  • Web Developer.
Hardware issue?
« on: May 08, 2013, 06:33:05 pm »
So I finally have enough parts to at least start the computer. It is the first computer I have ever built. Early this morning I found the motherboard manual online, located the power switch pins, and carefully jumped them with the tip of a pair of scissors. Whola! A bios screen or something. Too tired to continue playing with it, I flicked the psu off.
This afternoon, I did the same process to turn it on again, and nothing happened. Any ideas?
Here is the components:
Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32100
Foxconn H61MX LGA 1155 Intel H61 Micro ATX Intel Motherboard
CORSAIR Vengeance 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ4GX3M1A1600C9B
CORSAIR CX430M 430W ATX12V v2.3 80 PLUS BRONZE Certified Modular Active PFC Power Supply
sandheaver
Re: Hardware issue?
« Reply #1 on: May 08, 2013, 06:41:37 pm »
did you turn the PSU back on?
keilmillerjr
  • Web Developer.
Re: Hardware issue?
« Reply #2 on: May 08, 2013, 06:46:14 pm »
Yes. I've tried it with the switch in both positions.
404
Re: Hardware issue?
« Reply #3 on: May 08, 2013, 07:02:19 pm »
did you try to pull the bios battery? I was experimenting with a board recently which suffered from similar symptoms. I pulled the bios battery and it ran fine when i put it back in.
also next time you try to turn on the pc by shorting the switch posts, try using something smaller than scissors, like a small flat head screwdriver.
keilmillerjr
  • Web Developer.
Re: Hardware issue?
« Reply #4 on: May 08, 2013, 07:22:08 pm »
I'll try both of your tips when I get home from work at 4:30am. Thank you.
ed12
Re: Hardware issue?
« Reply #5 on: May 08, 2013, 09:20:36 pm »
turn off the psu
un-plug it even from the a/c
wait about 3 min's
turn it back on
do the trick shorting the start button's
if it come's on ? to bios
go to bios advanced setup
find the power option
turn it to  >turn back on after power faulier<
save/exit
shut psu off at its switch
or un-plug
then turn it back on
the unit should power right back up
if not remove bios battery
and wait about a min or 2
place batt back in
and do a full cmos setup >cmos=bios<
ed
05SRT4
  • Last login:Yesterday at 06:35:32 pm
  • Check out my Pow Pow
Re: Hardware issue?
« Reply #6 on: May 09, 2013, 03:14:11 am »
So when you trip the power contacts on the mobo does anything happen? (CPU fan turn, PSU fans turn, any noises?)
Defiantly try the mentioned above.
keilmillerjr
  • Web Developer.
Re: Hardware issue?
« Reply #7 on: May 09, 2013, 04:49:48 am »
So I grabbed my iFixIt screwdriver set and removed the battery. Hit the jumpers and all works well now. I started up and shut down a few times to make sure. So glad I don't have a defective product. Thank you all for your help. Next step is a hard drive. Almost done with the software setup via virtualbox on my mac. I'll then make a bootable image and copy it onto the mame computer.
404
Re: Hardware issue?
« Reply #8 on: May 09, 2013, 08:11:22 am »
glad to hear its working. I've had the issue before, I found more often than not, the bios was set to recover after a power failure. Consider looking into that in the bios settings.
