Main > Everything Else
Switch
<< < (3/3)
jmike:
I used something similar for a fight stick a while ago. Buttons lit up when you pressed them. (can't really remember what that was called  :dunno but I think I might still have one laying around the house somewhere) It was something like the Sparky SMD LED controller.
I'll take a look when I get home. Still had some pics of it on my desktop.
mpm32:
I figured it out.
The four corners of the plexi are screwed in.  I have a center bar running the length of the box under the plexi.
I drilled a recess for a spring so the center of the plexi gets supported.
I then put a microswitch with a lever on the side of the center bar so that when you step on the plexi, the switch gets depressed.
Works pretty well.  I'll take pics soon.
ChadTower:
Heh.  He just pretty much described the construction of a pro wrestling ring.   :laugh2:
Howard_Casto:
--- Quote from: ChadTower on May 15, 2013, 09:17:22 pm ---
No, he didn't put a microphone underneath to make the bumps sound like they are killing each other.  ;)
mpm32:
I finished them. Since these pictures were taken I have painted them and the case hardware has been added.
There are three of them one is slightly smaller than the other two so it can nest in between them and be locked together for travel.  I'll have pictures of them in action after Friday's gig.
Navigation
[0] Message Index
[*] Previous page
Go to full version
