Author Topic: m  (Read 1009 times)
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
m
« on: May 03, 2013, 11:58:59 am »
m
« Last Edit: May 03, 2013, 01:00:35 pm by mo1e »
lilshawn
  • Last login:Yesterday at 08:27:40 pm
Re: is this worth it??
« Reply #1 on: May 03, 2013, 12:10:03 pm »
can you source a 19" 4:3 or 5:4 monitor though?
otherwise looks okay. if you wanted less buttons or a different layout, you'd have to cut a new piece. I would have rather had that part left blank.
i dont see a grove or anthing to mount the marquee or monitor "glass" so that's another consideration.
it may be worth picking one up and even if you just use it for ideas to cut your own. (add a little here, cut a slot here, take a little there)
mo1e
« Reply #2 on: May 03, 2013, 12:13:41 pm »
yes well he said he will leave the control panel blank for me. as im unsure whether i want a 1 player or 2 player cab. also i have a spare monitor, buttons and sticks so im good to go. im just awful at woodwork.
  • Last login:March 21, 2024, 08:20:28 am
« Reply #3 on: May 03, 2013, 12:25:28 pm »
Honestly, there are only a few bartops i can think of that don't look cramped when having 2 players. If you primarily will be using it 1 player, think about just having a separate gamepad or joystick for player 2.
mo1e
« Reply #4 on: May 03, 2013, 12:32:49 pm »
yeah i will keep it one player. do you guys see anything wrong with the layout of that control panel? if so i can order it blank?
Drnick
  • Last login:May 06, 2023, 01:19:48 pm
  • Plodding Through Life
« Reply #5 on: May 03, 2013, 12:38:39 pm »
If I remember correctly that would be one of Tippers Bartops.  Button layout is fine, I would add a 2nd button on the front panel, 1 for coinup and 1 for start.  Sure you can use shifted buttons to do it but I like having 2 buttons.
  • Last login:April 28, 2024, 12:59:28 pm
Re: m
« Reply #6 on: May 03, 2013, 01:02:36 pm »
M?
Re: m
« Reply #7 on: May 03, 2013, 01:09:52 pm »
M?
C'mon man, it's for "Mole". Like Zoro. ;D
Drnick
Re: m
« Reply #8 on: May 03, 2013, 01:16:01 pm »
Originally it was something along the lines of is this a good deal and an ebay link.  Obviously hoping to get the lowball on it if nobody else knows about it  :laugh2: :laugh2:
Re: m
« Reply #9 on: May 03, 2013, 01:18:12 pm »
mo1e
Re: m
« Reply #10 on: May 03, 2013, 02:04:11 pm »
ha. no im not trying to get the low ball. just worried incase the seller is a user on here.
but yeah it is fully that you guys thought i left a calling card with the M.
zorro came, zorro asked, zorro got answers, zorro left
« Last Edit: May 03, 2013, 02:07:06 pm by mo1e »
lilshawn
Re: m
« Reply #11 on: May 03, 2013, 07:05:58 pm »
hell, if he is a user here you could probably get the BYOAC bro discount.  ;D  :cheers:
no need to edit out your post    :-\
