Main > Everything Else
Hey Vigo!
<< < (3/3)
Howard_Casto:
--- Quote from: SavannahLion on May 05, 2013, 04:21:05 am ---
--- Quote from: Howard_Casto on May 04, 2013, 11:05:10 pm ---Not really... or at least I've never been able to do it properly.
Every tried to use that stuff on a sheet of paper?  It seldom turns out well.
3M makes a number of spray adhesives that have slightly different characteristics and applications. Even their "standard" Super 77 has slightly different formulations depending on where you buy it (California vs everyone else). For instance, I've used the styrofoam spray and glues to repair foam cores before and the bond ends up being stronger than the actual foam yet it's still super easy to carve through. But getting used to how it's applied was kind of a pain.
If the sheet is really vinyl, then 3M's #80 might be more suitable? Package says it can be applied to wood but I don't know if it would work well on a painted wall.  ??? Personally, I think it would be far cooler to build something that resembles the frame from the movie and mount it that way. Then the whole adhesive business is moot.  :cheers:
We went off topic and were referring to arcade related applications... side art and what not.  For that painting you'd go down to the home depot, buy some lumber and stretch it around a wooden frame like a traditional canvas.  (I'd say get canvas ribs and do it the right way, but a set that big is really expensive).
Howard_Casto:
--- Quote from: HaRuMaN on May 05, 2013, 01:28:15 pm ---Souldraw is really cheap for self adhesive vinyl & marquees.  I just got a set of sideart and a marquee for my Weecade clone printed & shipped for $35.  From China.  And it arrived in less than 2 weeks from placing the order.
The Vigo painting would cost approximately 65 dollars from that site printed to a cheap canvas.  Like I said, the original is a little steep.  ;)
Navigation
[0] Message Index
[*] Previous page
Go to full version
