Main > Main Forum
Led Viewing Angle?
<< < (2/2)
Brian74:
Thanks for the replies guys. Have the leftover il translucent centers from my other cab. Thought I would throw some single color leds in them.
Sent from my SGH-T989 using Tapatalk 2
PL1:
To determine the correct LED to use, measure the width of the button surface you want illuminated and the distance (button depresed) to the top of the LED.
Draw the viewing angle of the LED, mark the distance on both legs, and measure the distance between marks.
If the distance between marks is shorter than the illuminated surface diameter, it will cause a "hot spot".
Brian74:
Scott my friend, you are full of useful knowledge!!! Thanks for the help! :D
matsadona:
The so called "straw hat" LED's have a wider angle, and might be better suited for this.
lilshawn:
ive also carefully filed the tops flat on standard led's to make them wider angle.
Navigation
Message Index
Previous page
Go to full version
