Main > Driving & Racing Cabinets
PPSSP: New version is out! Ridge Racer PSP on the big screen!
SegaOutrun:
How are you using your steering wheel with ppsspp? I was playing intial d the other day and gave up trying to find the right settings. way too sensitive
isamu:
--- Quote from: SegaOutrun on May 11, 2013, 03:00:10 pm ---How are you using your steering wheel with ppsspp? I was playing intial d the other day and gave up trying to find the right settings. way too sensitive
what kind of wheel do you have bro? I'm guessing a 900 degree wheel like the Logitech G25/G27? Anyway the reason it appeared too sensitive is because ppsspp probably thinks the wheel is a digital input device. Or maybe the settings in your drivers are where it's too sensitive. What I'm doing is using a virtual joystick through an app call ppjoy. Then I proceed to tweak and calibrate the analog steering input through ppjoy's calibration menu. On my 9000 degree ECCI 7000 wheel, I turn the wheel about JUST *SLIGHTLY* PAST 90 degrees in each direction, then calibrate the gas and brake pedals. PPSSPP will see ppjoy as your 1st joystick, and you will then be able to steer the cars the way you want. Keep tweaking the analog steering in ppjoy til you get the results you want. You make it as sensitive or non-sensitive as you want. Hope that helps :)
MartinJames:
I cant get any Ridge Racer roms to work, just a black screen. What am I doing wrong?
isamu:
--- Quote from: vtivti on May 12, 2013, 08:11:58 am ---I cant get any Ridge Racer roms to work, just a black screen. What am I doing wrong?
Hm not sure bro. You sure you have the emulator pointed at the right roms directory?
Malenko:
its more of an ISO / CSO than a rom....
Navigation
[0] Message Index
[*] Previous page
Go to full version
