Main > Everything Else
Anyone here use NAS (Network Accessible Storage) devices?
<< < (13/14) > >>
lilshawn:
--- Quote from: wesbrown18 link=topic=131546.msg1356340#msg1356340 ---I built a 40gbps Infiniband fabric for the HPC cluster at my $DAYJOB, and there is so much lore involved.  But we push 8 gigabytes a second of data, continuous, across the entire fabric.
i'm too lazy/cheap to buy a gigabit switch for my network. still runnin' 100  :lol
MonMotha:
I honestly don't know how people put up with 100Mbps LANs, anymore.  I'm seriously considering upgrading to 10GbE. The only reason I haven't is that most of my storage at the moment is cheap and can't really go much faster than 1Gbps, anyway.
drventure:
Gigabit's cheap. I don't know much about 10gb so I can't comment there.
shponglefan:
Gigabit is definitely worth it over 10/100.  I recently upgraded my network to gigabit; turns out I just needed to replace one 10/100 switch and it cost all of $30 to do so.
However, I can't see going faster.  I find I top out my network speeds at about 40-45 MB/s (uploading to my NAS).  Looks like HD speed is the limiting factor.  I suppose if I had striped RAID on both ends, it would be faster, but honestly doesn't seem worth it at this point.
wesbrown18:
--- Quote from: shponglefan on May 01, 2013, 08:13:21 pm ---Gigabit is definitely worth it over 10/100.  I recently upgraded my network to gigabit; turns out I just needed to replace one 10/100 switch and it cost all of $30 to do so.
If you just replaced your switch, you should consider replacing the ethernet cabling with good quality Cat-5e.  I've done extensive testing with Gigabit, and find that usually when we hit 50MB/s, it's an issue with the cabling.  What's adequate for 100mbps isn't adequate for Gigabit.
You can get about 100MB/s to and from a consumer-grade NAS if you have about four drives.  If you have it in a RAID-5, it's going to really slow things down.
My own setup pushes 400MB/s, but that's with aggressive caching, look-ahead reads, a caching SSD, and a pair of log SSDs for writes, and 32GB of RAM pretty much devoted to the NAS.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
