Main > Main Forum
20" 4:3 aspect ratio vs 23" 16:9
BobA:
The table shows that the 20 inch monitor has more height than the 23 inch wide as Mameshane noted above.
20 inch 4:3 is 12 inches high
23 inch 16:9 is 11.3 inches high
lettuce:
What I having been toying with and i have no idea if its even possible is to, get a 27" wide screen, mount it vertically and have the top section of the screen as the marquee for each game and the lower section for the usual game display!
Bender:
I had this same dilemma
I ended up getting a 24" LED LCD for around $100
I'm just running it in 4:3 mode and I'm going to crop the excess off with the bezel so you'll never know its a 16:9 tv in there. Plus the thing only weighs 6lbs and uses almost no electricity
The viewable size is about 11.75" high.
yotsuya:
--- Quote from: lettuce on April 01, 2013, 05:25:15 am ---What I having been toying with and i have no idea if its even possible is to, get a 27" wide screen, mount it vertically and have the top section of the screen as the marquee for each game and the lower section for the usual game display!
I'm sure you could do that using .lay files.
markc74:
That's something i toyed with before getting a marquee monitor. It's definitely doable with lay files but will only work with mame afaik.
