Main > Main Forum
Insert Coin/Coin Reject
Pages: << < (7/7)
mgb:
Arcadebliss,
  I like that approach, I agree that if a switch goes bad, it will be a little bit of a pain to replace (far from impossible though) but the epoxy gets you around the trouble of the screws interfering.
Nicely done, isn't epoxy great. :applaud:
ArcadeBliss:
Since I started this hobby, I've had maybe two cherry switches die. When I think about how much a coin up switch is used, I have very few worries about it. Considering I usually just pop tokens in the machine. It is faster sometimes.
Cheers
mgb:
True. Cherry switches don't often go bad
Unstupid:
And if you wanted to get more stealthy you can wire up both coin reject buttons so that you'd have to push both to get a credit...
ArcadeBliss:
Very sneaky ;D
Pages: << < (7/7)
Go to full version
