Main > Monitor/Video Forum
Tatung Monitor Won't Start
Titan91:
Interesting, I'll test it live then and check for voltage there. Moving away from the chassis I started checking the yoke windings. Horizontal is 1.1ohm and vertical is 3.5. Isn't that a little low? Also, the chassis board isn't grounded. There is no ground tab on the output side of the EMI filter so looks like it was changed. Would no ground cause the monitor to not start?
Titan91:
Discussion continued here:
http://forum.arcadecontrols.com/index.php/topic,131410.0.html
tuffjam:
--- Quote from: ed12 on March 16, 2013, 09:49:57 pm ---hi
if u want to print these blow them up to 200%
ed
Hi ed... do you hapen to know where i can find the schematics for a TATUNG VT19726Z out of megatouch force 19"?
thanks
