Main > Project Announcements
My First Build - Dual Stick Controller Project
chemikalguy:
Using CAT5e or CAT6 cables for buttons to keep the install neat
Trimming cables to remove excess
Completed cable install
HaRuMaN:
Man... such nice work, but you gotta fix that vinyl...
chemikalguy:
My quality control tester...
Drnick:
Please pull that contact paper from the top and replace it . I got good results with 3M Carbon fibre, I know that Griffindodd used it on his Marvel Build and I have seen it on some other projects. You won't get that bubbling that you are currently getting, Just sand down the Mdf & put a touch of primer or something on any cut edges. Go on do it, I bet you won't be happy until you do.
thefox:
Nice work ! I discovered that contact stuff can be a real pain to get smooth & stick properly. Took us a few attempts and a few wasted sheets of the stuff. (It seems to stick to the workbench, the floor, and the bin ok though!)
Like you said, I found a sharp blade on the holes is a must, and it only sticks to the smooth stuff. Any unprimed cut edges just wont stay in contact with it.
Look forward to seeing what you do next...
Navigation
[0] Message Index
[*] Previous page
Go to full version
