Main > Main Forum
Ipac2 and keyboard conflict
Chiefcob:
OK I have a specific button set to escape and this works when exiting a game run only by mame and using the control panel in hyperspin frontend.
When trying to escape a game run through hyperspin the escape button does not work and the only way to escape is to end the task any ideas on how to solve this?
Drnick:
Have you got Hyperlaunch turned on or off? It should be Off. Try that just in case Hyperlaunch is expecting a different quit key to what Mame/Hyperspin are expecting. It should be an option for the mame wheel in HyperHq if I remember correctly.
Chiefcob:
No luck with disabling hyperlaunch in hyperhq. It allowed me too select my game but wouldnt accept the controls to start the rom.
The only problem Im having is that for some reason the escape button will not function during a game but works fine in hyperspin and mame. ???
Drnick:
I would post the question over at the HS forums, in my experience it has always been an incorrectly configured esc button or hyperlaunch.
Chiefcob:
Will do thanks doc!
