Author Topic: Control Panel Question  (Read 657 times)
GoYouSalukis
  • Last login:March 18, 2020, 11:58:59 am
« on: March 06, 2013, 12:27:47 pm »
I am building my control panel on my small CNC machine. I've been cutting both the acrylic and plywood at the same time. How do you guys secure the edges of the acrylic to the plywood? Of course it will be held down in the middle by the buttons, but what about the edges? I plan to have wood->sticker->acrylic. I was planning on putting t-molding around the edge.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: Control Panel Question
« Reply #1 on: March 06, 2013, 12:36:46 pm »
Its not held by anything... just offset the t-molding such that it overlaps the plexi.
Happy Gaming!
keilmillerjr
  • Web Developer.
« Reply #2 on: March 06, 2013, 03:40:35 pm »
I remember going to arcades and the machines with plexi used to cover instructions were usually held by screws on the corners, either counter sunk in or button type.
dandro
  • Last login:July 20, 2014, 12:32:46 am
    • Link To project
« Reply #3 on: March 06, 2013, 03:42:27 pm »
This is what I will be doing, since it's not going anywhere except my house, I want it clean, free off screws that are apparent and easy to replace artwork, should I choose to change themes later, or convert this cab to a dedicated Jamma cab. :)
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #4 on: March 06, 2013, 03:59:16 pm »
if theres a chance you`ll be taking the plexi on and off a lot i`d say use carriage bolts in the corners with wingnuts underneath or your t-molding will get damaged eventually
Hit something hard enough it should work, if it dont the result can always be called art :)
shponglefan
« Reply #5 on: March 07, 2013, 06:35:36 am »
You don't need the secure the edges.  It will sit flat and the buttons do enough to hold it down.  And T-Molding prevents anything getting underneath it and accidently raising it.
Garza
  • Last login:July 09, 2015, 10:53:29 am
« Reply #6 on: March 07, 2013, 03:33:40 pm »
Yes you don't have to put anything to tie down the edges if you dont want to I currently have just my buttons holding down the plexi and nothing on the edges except t molding for over a year now and its worked perfecty.
GoYouSalukis
« Reply #7 on: March 07, 2013, 03:57:32 pm »
Thanks guys,
I was probably overthinking it.
jimbo123
  • Last login:April 08, 2024, 10:17:06 pm
« Reply #8 on: March 07, 2013, 04:34:23 pm »
In the CP box I'm putting together, I'll be unable to hinge the top and it's also a little difficult to hold it down from the inside. So I'll be putting dome headed bolts through to thread inserts.
