| Main > Software Forum |
| Street Fighter x Tekken failing to save on Win XP 64-bit only. |
| << < (7/9) > >> |
| yangfeng:
I would check around to find out where the game is supposed to save and manually make a save file. You can probably download one off the net. _____________________________________________________________________ You Are the One, I take a bubble Cheap D3 Gold Buy Runescape Gold Buy RS Gold |
| DeLuSioNal29:
--- Quote from: yangfeng on May 21, 2013, 03:59:24 am ---I would check around to find out where the game is supposed to save and manually make a save file. You can probably download one off the net. --- End quote --- Already tried this. Ran it on my Windows 7 64-bit system, saved the files. Copied them via USB drive to my arcade machine running Windows XP 64-bit. Didn't work. |
| DeLuSioNal29:
Quick update: There is hope at the end of the tunnel. Capcom finally contacted me (after filing a complaint with the BBB). They are working with me to troubleshoot the issue (first step is to provide them a DXDIAG output on the Win XP 64-bit OS machine. Stay tuned! DeLuSioNaL29 |
| ArcadeBliss:
Yahoo. Keep us posted |
| DeLuSioNal29:
I just wanted to give you guys an update. I responded back to Capcom (via their support link) after they contacted me. Here's what I wrote: (attachments noted in the request are posted below for reference purposes) --- Quote ---5/28/2013 Attached are files related to not being able to run SFxT with Windows XP 64-bit. 1) DxDiag 64 bit XP.txt 2) Screenshot 1.jpg 3) Screenshot 2.jpg When first running the game, Screenshot 1 pops up. If you select YES, then Screenshot 2 pops up. If you select OK, then Screenshot 1 pops up. Never ending loop. --- End quote --- And they replied with: --- Quote ---5/28/2013 Hello, Thank you very much for the information you have provided. We're still looking into the matter and will update you once new information is available. Best Regards, CAPCOM Customer Support --- End quote --- Fingers crossed. I will keep you guys posted on what happens next. :dunno I suggest you all create tickets of your own to state that it doesn't work with Windows XP 64-bit. Here's the link: https://www.fuzeqna.com/capcomsupport/consumer/question.asp DeLuSioNaL29 |
| Navigation |
| Message Index |
| Next page |
| Previous page |
