Main > Project Announcements
UAII - coerced into creating thread
Nephasth:
--- Quote from: ids on March 04, 2013, 02:00:17 pm ---Buttons lit with Paradise led's, which dont snap in as advertised - these are all hot-glued in.
Which ones are supposed to snap in that style of button?
ids:
These: http://www.paradisearcadeshop.com/en/button-leds/101-il-lumination-5vdc-led.html
Tho I see the snap in part is no longer mentioned. ;) Not a big deal tho, that's what hot glue is for.
ids:
More early pics...
1. This was on my desk for a looooong time - made building a cab difficult. Sure it's ugly but it worked.
2. Basic cab put together. I dont recommend cheap plywood, unless you're covering it with formica or something. I spent way too much time trying to make it smooth via sanding, bondo, spot putty, sanding, ....
2. Testing the final (iirc) panel - this was before the mini display arrived and had it's hole cut in there. From here you can see that the plr3+4 sticks are not angled - not that there's anything wrong with that ;D
ids:
Oh, forgot to mention, colour matched custom dust-washers by Randy (GGG) - love those things.
Related (or not) Links:
* Custom coin door lighting
* Q*bert knocker
* Custom software for the raspberry-pi
* Ms Pac desktop panel
* Air Hockey Build
* The workshop
ids:
Mounted the serial plate properly:
also made some improvements to my software which is running on the r-pi, and configured Hyperspin (via the autohotkey script) to call out to it - working quite well at the moment
Navigation
[0] Message Index
[*] Previous page
Go to full version
