Author Topic: Ipac 2 Terminals  (Read 2348 times)
Beaker
  • Last login:December 04, 2014, 10:12:49 am
Ipac 2 Terminals
« on: February 27, 2013, 11:24:55 am »
Hi everyone!
Just a quick question about the Ipac 2.
As I intend to use two ultrastick 360 joysticks (USB) Can I use the joystick terminals (up,down,left,right) on the ipac 2 for extra buttons instead?
Any thoughts and opinions are appreciated! 😃
boomstick
  • Last login:March 03, 2024, 04:35:07 pm
    • James Clay Photography
Re: Ipac 2 Terminals
« Reply #1 on: February 27, 2013, 11:41:39 am »
Pretty sure you should be able to do so with ease.
You will need to use the WinIPAC IPD programming utility from the Ultimarc site to re-assign the P1 & P2 UP, Down, Left & Right inputs to different keyboard inputs so as you can use them for other commands.
Info here: Ultimarc Winipac IPD
Download here: WinIPAC Download Page
« Last Edit: February 27, 2013, 11:50:47 am by boomstick »
Beaker
Ipac 2 Terminals
« Reply #2 on: February 27, 2013, 12:04:33 pm »
Cheers boomstick!
So, by doing as you suggested it would seem possible to have 8 buttons per player using SW1 to SW 8 (street fighter & modern consoles)
2 pinball buttons per player using 1A,1B,2A,2B
8 admin buttons or less (not a fan of shift) using  player 1 and 2 joystick inputs.
Don't mean to come across stupid but am I on the right track?
boomstick
« Reply #3 on: February 27, 2013, 01:59:57 pm »
That should certainly be feasable by reprogramming the IPAC2.
One other option you have within the winIPAC software is to program a SHIFT funtion for each input on the board.  This would allow you to have all admin buttons opperate as a shifted function of another standard input.  For example, you could set "TAB" to shifted P1 SW1, "ESCAPE" set to shifted P1 SW2 and "ENTER" set to shifted P1 SW3.  You can basically asign any key to any input or shifted input.  This lets you keep a clean CP without cluttering it up with admin buttons.
By default, P1 Start is setup as the shift button.  If you hold this down to enable the SHIFT feature, and press another key, for example, P1 SW1, you can have the IPAC send the programmed shifted keyboard output (eg TAB) rather than the non-shifted default output of L.Ctrl
Of course, you can always have dedicated admin buttons if you prefer, or a mix of both
Hope this helps
Edit: Just re-read your post "not a fan of shift inputs"
« Last Edit: February 27, 2013, 02:46:40 pm by boomstick »
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #4 on: February 27, 2013, 02:02:45 pm »
Cheers boomstick!
What do you need up to 8 admin buttons for? The IPAC has inputs for 1/2 Coin and 1/2 start.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: February 27, 2013, 02:51:24 pm »
All this is possible but you would not generally need dedicated connections for pinball buttons, just connect them to the same connections as standard buttons, assuming they are not used in the same game for different functions.
  • Online Online
  • Last login:Today at 04:02:56 pm
« Reply #6 on: February 27, 2013, 05:38:34 pm »
Beaker -- There is some overlap between MAME and the pinball functions -- see here.
P1/P2 Start and P1/P2 Coin are, technically speaking, admin buttons.
If he adds Escape, Pause, Enter, Tab, Left Mouse and Right Mouse that's 10.
It may end up looking like a "bag of skittles" if he adds too many, but it's up to OP to avoid that.  :duckhunt
Beaker
Ipac 2 Terminals
« Reply #7 on: March 23, 2013, 07:14:23 pm »
Andy, PL1 and Scott - Thanks for you comments, I've got a better idea now thanks to you guys. Appreciate the help!
Andy, just wanted to say that your products are pure class, myself and the rest of the arcade community have benefited immensely from your technical genius and passion for making truly awesome controls. Keep up the good work mate, it's really appreciated :-)
Sent from my iPhone using Tapatalk 2
