Main > Everything Else
Too case or not too case
<< < (2/3) > >>
mahkeymike:
--- Quote from: BadMouth on February 22, 2013, 06:05:46 pm ---Use something better than a jigsaw to cut it or you'll end up with edges like this.
Angle grinder or dremel with heavy duty cut-off wheel would have been much better.
Harbor Frieght....
There called Nibblers
THIS
OR THIS
Howard_Casto:
Actually, I've had really good luck with jiggsaws for cutting cases, back in my "modding" days that's what I used.  Every now and again you'll need to smooth things out, but the edge is fairly clean.
You just have to use the right blade.  Man, I dunno what BadMouth did, but you've got to work really hard to screw it up that bad.  ;)
monkeychunkuk:
Apart from the look what Are the draw backs on leaving them inside a stripped down cab?
danny_galaga:
--- Quote ---Too case or not too case
I don't think it's too case at all, seems to be just the right amount of case...
Generic Eric:
I can't add much to what has been said.  I like the exposed PCB though.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
