Main > Everything Else
Too case or not too case
<< < (3/3)
SithMaster:
If you have a dell dimension series case you want to scrap you could easily drill out the rivets and just have the one side to mount a mobo, psu, optical drive, and hd depending on model of the case.
I'm somewhat positive that trying to cut a pc case somewhat fast with a jigsaw will cause edges like that.  Best to go slow and let the blade do its thing.
Drnick:
--- Quote from: monkeychunkuk on February 22, 2013, 07:49:43 pm ---Apart from the look what Are the draw backs on leaving them inside a stripped down cab?
There are only a few things I have noticed. Noise from fans sounds louder with no case. Then there is Dust and Fluff in the fans.  To deal with that you can just put a filter over your cabinet fans.
Howard_Casto:
Honestly it's better to leave the pc cased.  That way when (not if) the pc dies, you can just swap it out instead of unmounting a pcb tray, power supply and ect.  Sometimes you have to de-case though.... there just isn't enough room in the machine.
Gray_Area:
--- Quote from: BadMouth on February 22, 2013, 06:05:46 pm ---
Use something better than a jigsaw to cut it or you'll end up with edges like this.
Angle grinder or dremel with heavy duty cut-off wheel would have been much better.
Board and clamps make a handy fence.
edekoning:
If you already have the case and the space for it, than use it. If you still need to buy all the computer parts, than you can save a few bucks by not buying a case.
Navigation
[0] Message Index
[*] Previous page
Go to full version
