Author Topic: soft15khz help  (Read 1045 times)
fogisgod
  • Last login:March 14, 2013, 07:09:40 pm
soft15khz help
« on: February 18, 2013, 05:41:50 pm »
Hi all
I have a Virtua Striker cab which has a medium res 25khz monitor, will soft15khz when installed on my computer enable me to emulate classic 15khz games on the 25khz monitor.
Cheers
fogisgod
Re: soft15khz help
« Reply #1 on: February 18, 2013, 06:01:24 pm »
Also when I run soft15khz do I install 15khz or 25khz onto my graphics card as the monitor is 25khz...... Stupid question but just want to make sure I can run 15khz games.
kathrin
  • Newbie
  • Last login:April 13, 2013, 03:21:45 am
Re: soft15khz help
« Reply #2 on: February 19, 2013, 05:43:57 am »
I like it,ts very nice and informative four others,amazing
certkiller exam dump questions   certkiller exam dump questions
cissp boot camp   cissp boot camp
ccna service provider   ccna service provider
fogisgod
Re: soft15khz help
« Reply #3 on: February 19, 2013, 12:11:51 pm »
Can anybody help on this matter please.
rCadeGaming
  • Last login:December 20, 2023, 09:16:09 pm
  • Just call me Rob!
Re: soft15khz help
« Reply #4 on: February 19, 2013, 04:41:24 pm »
No, you won't be able to run 15kHz native resolutions on your 25kHz monitor.  A 25kHz monitor can only display 25kHz resolutions.  You'd have to scale 15kHz resolutions up somewhat, and it won't scale very evenly.  15kHz means around 240p, which scales much better to 480p, which you'd need a 31kHz monitor for.
Are you positive your monitor is 25kHz only?  You'd need a different display do get a nice picture with anything other native 25kHz games, of which there's not many good ones.  Get a 15kHz monitor, a trisync 15/25/31kHz monitor, or a 15kHz "standard definition" CRT TV.
Mr_Goshki
  • Last login:September 22, 2019, 06:07:06 pm
  • Play Games From 86-96
Re: soft15khz help
« Reply #5 on: April 04, 2013, 03:31:12 pm »
If it's got a sega nanao monitor (like all vf/vs cabs i've seen) there's a jumper on the monitor chassis that makes it run in 15k mode.
If your not sure take a photo and i'll let you know if it's there.
I've also played around with soft 15k, if your chassis has the jumper change it and install 15k mode.
If it's got no jumper and your stuck with 25k, just install with 25k mode and see what it looks like, you might be able to adjust better using emulators built in adjustments.
Hack or Restore, always hardcore.
