Author Topic: exterior neon lighting???  (Read 1796 times)
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
« on: February 15, 2013, 11:30:57 am »
Im sooo confused and lost in the world of lighting...im looking for something to accent the outside of my cab and hide a few neon/led strips on portion below the controls and possibly somewhere else. The cab will be painted black and the trim is red. I dont need anything insane only because how often am I going to playing this thing in the dark. I was thinking of running cold cathode tubes but not sure on powering them or being able to turn them off without unplugging wires...
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
Re: exterior neon lighting???
« Reply #1 on: February 15, 2013, 11:47:34 am »
Go with LED strips.
willybeamish
« Reply #2 on: February 15, 2013, 11:52:21 am »
Will do thanks you like those better than the cold cathode tubes??
shponglefan
« Reply #3 on: February 15, 2013, 11:52:39 am »
I recommend the Sylvania coloured LED strips.  They can be turned on/off via remote control and set to a variety of different colours.  You should be able to find them at Home Depot.
« Reply #4 on: February 15, 2013, 11:58:21 am »
Yep. Check out the Two-Headed Beast in my signature. Cheap Chinese RGB strips, an LED-Wiz, and LEDBlinky is how I set up my cabinet lighting that can change based on game selection, and machine events such as pause, game loading, front end, and sound reactive. I've got about $45 in the cabinet lighting on that machine.
willybeamish
« Reply #5 on: February 15, 2013, 12:03:18 pm »
Man I would love to run LED Blinky..im a sucker for flashy lighting. After I finish up setting up Hyperspin I might look into it.
willybeamish
« Reply #6 on: February 15, 2013, 12:29:35 pm »
  • Last login:Today at 04:02:56 pm
« Reply #7 on: February 15, 2013, 01:24:48 pm »
Why not use a 120V AC - 3V DC "wall-wart" like this?
willybeamish
« Reply #8 on: February 15, 2013, 02:04:46 pm »
As long as somebody tells me exactly what adapter to buy im up for it..im a noob with electricity and fear burning the house down.
« Reply #9 on: February 15, 2013, 02:22:31 pm »
With LED strips, you just tap into your computer's power supply. No need for a power adapter.
willybeamish
« Reply #10 on: February 15, 2013, 02:29:06 pm »
I started checking out your build at work now didnt have time to run threw 11 pages yet at the moment to find the led section lol. Im up in the air about leds vs neons...I know they put out different types of light.
« Reply #11 on: February 15, 2013, 03:30:29 pm »
This post on page 7 is where the LED strip fun begins.
Scroll down for the e-bay link.
Brian74
  • Last login:March 10, 2024, 01:55:58 pm
  • Yep... I built that!!
« Reply #12 on: February 15, 2013, 06:49:20 pm »
Here is my Cab with some RGB goodness!!  :cheers:
willybeamish
Re: Re: exterior neon lighting???
« Reply #13 on: February 15, 2013, 07:21:19 pm »
Holllyyy ---steaming pile of meadow muffin--- lol.. The control panel is nuts that must of cost a small fortune? How did u go about getting the floor lights rigged up?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Brian74
« Reply #14 on: February 17, 2013, 01:03:05 pm »
I was lucky enough for x-mas/bday last yr to get the buttons the trackball, upgrade kit and 2 led-wiz from my gf. Here are the LEDS I used underneath. http://www.ebay.com/itm/300851365398?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
