Author Topic: Which Front-end  (Read 2378 times)
Mike Wazowski
  • Last login:February 14, 2013, 01:52:36 pm
Which Front-end
« on: February 14, 2013, 04:10:00 am »
Dear all,
A few years ago I build a cocktail table with MameWah as front-end. Benefit of this was that I could hide the Windows start up and the programme worked with the controls.
Yesterday I downloaded the a new version of Mame because I started a new project. It seems that MameWah does not work with the latest version of Mame.
I would like to now which todays front-end I could use with the functions of MameWah. MaLa Frontend?
Pleas advise.
Dcpmark
  • Last login:December 30, 2023, 11:28:10 pm
Re: Which Front-end
« Reply #1 on: February 14, 2013, 09:07:01 am »
From my research the 3 most popular frontends appear to be Mala, Hyperspin, and Maximus Arcade. Maximus is not currently under active development, but it's pretty.nice in its current form. That is what I chose recently.
Sparkolicious
  • Last login:May 25, 2022, 05:41:24 pm
  • Measure twice cut once dern it!
Re: Which Front-end
« Reply #2 on: February 14, 2013, 09:48:02 am »
I like hyperspin.  Some folks would argue that it is difficult to set up, but I haven't had much of an issue with MAME.  Some of the consoles take a little effort and tweaking, but with a small donation you have access to everything you need.  I have managed to get through all of my setup using information available on the forums. Now with hyper sync, you can automatically download themes, artwork, and vids for dozens of systems without having to search anywhere.  It is really neat!
  • Last login:May 05, 2024, 08:59:50 am
Re: Which Front-end
« Reply #3 on: February 14, 2013, 10:20:02 am »
What functions are you referring to?
shponglefan
Re: Which Front-end
« Reply #4 on: February 14, 2013, 12:20:05 pm »
I like Mala.  Easy to set up, can look really nice (w/ proper design/layout), not too flashy.
ThumperSoup
  • Last login:April 01, 2013, 04:46:05 pm
  • Warrior needs food – badly!
Re: Which Front-end
« Reply #5 on: February 14, 2013, 01:32:38 pm »
I'm in the midst of putting my cocktail cab together, and I'm going with Mala. I was going for something simple, and it seems to do the job. I wish there were a few more pre-made layouts that worked for a cocktail that will need to switch between horizontal and vertical, but I found one or two that will do the job.
Mike Wazowski
Re: Which Front-end
« Reply #6 on: February 14, 2013, 01:41:37 pm »
The nice things about Mamewah was that I could start the computer without interference of Windows, select games/ options and shut down with the joystick and buttons.
This is what I am looking for. Any idea?
Unstupid
Re: Which Front-end
« Reply #7 on: February 14, 2013, 02:32:50 pm »
For my next project I'm using Hyperspin, but Im building my own theme.  ;)
gonzo90017
Re: Which Front-end
« Reply #8 on: February 14, 2013, 06:26:29 pm »
What do you mean it doesn't work? Could you post the .ini file you're using. I'm sure your just not using the right parameters to generate the list.
cmoses
Which Front-end
« Reply #9 on: February 14, 2013, 10:23:49 pm »
I like HyperSpin myself. I have it on my full size arcade cabinet and I am building a cocktail cabinet currently. A user over on the HyperSpin forum named jeepguy81 created a great cocktail theme. He is in the finalizing stages and will be posting the complete version shortly. It shows how customizable the HyperSpin FE is.
Sent from my iPad Mini using Tapatalk HD
danny_galaga
  • Last login:May 05, 2024, 10:35:21 pm
    • dans cocktail lounge
Re: Which Front-end
« Reply #10 on: February 15, 2013, 05:33:18 am »
Another vote for Mala. I have it in my cocktail, which has a rotating monitor, so it's a nice touch that Mala can be set up so the menu orientation is always correct- horizontal or vertical (",)
welshjpc
  • Last login:March 12, 2020, 04:11:52 pm
  • Golden Tee cab project COMPLETE! :-D
Re: Which Front-end
« Reply #11 on: February 16, 2013, 05:04:36 pm »
I've gone for Maximus, maybe its the choice of newbies but it's my first attempt and it covered all of the bases that I personally required, as well as LOADS more that I don't (but may do in the future now!).
ABACABB
  • Last login:August 26, 2023, 12:37:07 pm
Re: Which Front-end
« Reply #12 on: February 16, 2013, 05:50:31 pm »
I went with GameEx and love it.  I am really surprised that no one mentioned it here so far.  It seems to be very popular and more importantly is is being actively developed and supported.  If you are just starting out, why would you choose something that is no longer being developed or supported??
GameEx has it's own support forum and tons of help there.  The developer himself usually replies to questions within a day or so.  I highly recommend this one.
Dawgz Rule
  • Last login:Yesterday at 06:34:49 am
  • The more people I meet, the more I like my dogs
Re: Which Front-end
« Reply #13 on: February 16, 2013, 06:41:05 pm »
+1 for GameEx.  Excellent support community and has a lot of nice features.
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
Re: Which Front-end
« Reply #14 on: February 16, 2013, 10:58:15 pm »
I really like Mala.
eds1275
  • Last login:May 03, 2024, 12:05:34 pm
  • Rock and Roll!
Re: Which Front-end
« Reply #15 on: February 17, 2013, 11:49:58 am »
I really like Mala.
I love it too, but it isn't without it's problems (background music!) The big upside for me is the low cpu usage though. My machines are resurrected computers from the past, and that helps a great deal.
Gaaargh
  • Last login:April 20, 2023, 02:27:52 pm
Re: Which Front-end
« Reply #16 on: February 17, 2013, 12:29:05 pm »
I'm another vote for MaLa. I used it on my cocktail Pac, with a text-free menu I 'shopped. It's lightweight, but has options for bigger performance - animations, music, lighting control, etc. plenty to like.
Kludged together a MAME cab 10 years ago, it got a makeover January 2012
2012 - built a cocktail Pacman near-repro running 60-odd vertical games Link
mgb
  • North East, US
Re: Which Front-end
« Reply #17 on: February 17, 2013, 03:33:36 pm »
I really like Mala.
yeah I'm sure it has issues but I wasn't aware of an issue with background music. I keep my frontend pretty simple. but I will say that I have it set up with a simple greeting message and that has been hiccuping lately but I thought it maybe had something to do with ledblinky starting up.
As far as frontends like Hyperspin go, I think they're very cool and I'm using Hyperspin on another more modern pc but for my arcade machine, I also have an older Pc (p4) that just runs better with a simpler frontend.
I like the frontend bling of Hyperspin but at the end of the day, its the games I enjoy most, not the list that I pick them from.
