Main > Main Forum
Re-using iCade technology
Man-Machine:
I basically want to continue playing MAME on my iPad (just like i've been doing with the iCade) but I want to for sure use a switchable 4-8 way joystick and better button switches. I'll need to rebuild the case because I can't find any switchable joysticks that will fit the plastic control panel.
I was thinking in perhaps adding an extra stick for games like Robotron and Crazy Climber. I don't know if it's going to worth it . Even though I don't play fighting games, this setup will leave me only two buttons to play the classic games.
I was hoping that someday I could play spinner and trackball games with it but I guess it won't be through the iCade technology since it shows up like a regular keyboard...
Cynicaster:
--- Quote from: Man-Machine on February 11, 2013, 03:25:16 pm ---I basically want to continue playing MAME on my iPad (just like i've been doing with the iCade) but I want to for sure use a switchable 4-8 way joystick and better button switches. I'll need to rebuild the case because I can't find any switchable joysticks that will fit the plastic control panel.
I’m assuming iMAME works the same as real MAME. If so, you could “share” the inputs for (4) of the buttons with a second joystick, and configure each game accordingly. This would at least get you into some twin-stick shooter action.
You may even be able to get some 2-player simultaneous stuff going, but you’d be limited to 1 button per player, which is very restrictive if not completely useless.
jammin0:
I've got iMame4all 4 on my iPad. I had an iCade at one point but gave it away. I just checked it out and it's looks like the key mapping is specifically for iCade and at least in the version that I have there is no control to custom map buttons.
Man-Machine:
Since I'm replacing the joysticks and buttons with better quieter microswitches, I'm just going to wired them how I like it. So I could give up 4, of the six buttons, to add a joystick.
Still, I'm trying to avoid having to re-do the cabinet. I would be really happy if I could just replace the original joystick with a switchable 4-8 way from Ultimarc or similar. Has anybody here done that?
TheGatesofBill:
Yea, electrically it's the same, so it'll work fine. I've got a IL Eurostick in mine.
