Author Topic: TMNT 1 : No sound  (Read 651 times)
ArcadeDunce
  • Last login:July 16, 2021, 11:30:20 am
TMNT 1 : No sound
« on: February 10, 2013, 05:24:00 pm »
back when  i was trying to repair my arcade board, I plugged in TMNT. it was working perfectly, but something went wrong and it started to smoke...
When we DID get the machine working again, the board still worked, but no sound.
any idea if this is an easy fix?  I don't want to trust ebay for a new board..
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
Re: TMNT 1 : No sound
« Reply #1 on: February 10, 2013, 05:59:17 pm »
Check the Repair boards over at KLOV. The TMNT board is a really well-documented one, and lots of folks over there have been round'n'round with them.
ArcadeDunce
« Reply #2 on: February 10, 2013, 07:38:27 pm »
well, i would if i could figure out how to register for there forums....i keep on getting mis directed and every time i try to log in, thinking i've figured it out, it says i'm not registered.. stupid confusing site :)
MonMotha
« Reply #3 on: February 11, 2013, 01:26:30 am »
Two things I've noticed:
The volume pot goes bad.  Wiggle it and see if you get any sound (static, etc.).  Be warned it may be REALLY loud.  The amp on that thing is surprisingly powerful, and if the pot's broken, you can easily end up with full volume when you don't expect it.
The amp/heatsink is bolted to the PCB and is quite big mechanically.  The PCB can easily crack, usually along the line of pins for the amp chip.  Often, this causes no electrical damage but breaks the solder joints.  Try reflowing them.
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:Yesterday at 09:33:37 pm
  • Worthless button pusher!
« Reply #4 on: February 11, 2013, 03:08:28 pm »
I have a TMNT board that I've been troubleshooting sound on for a long time, to no avail, but I don't recall doing either of MM's suggestions, so maybe I'll give them a shot tonight.
Dunce: when you register for KLOV, you will need someone to vouch for you. Post here letting us know your KLOV UserID and one of us can do the vouching. Good luck!
Working: Not Enough
Projects: Too Many
Progress: None
ArcadeDunce
« Reply #5 on: February 11, 2013, 08:52:41 pm »
SO I plugged it in after a long time and now i noticed it had video problems....should i have to buy a newer board..what would be a trusted place to go?
ArcadeDunce
« Reply #6 on: February 13, 2013, 02:38:56 pm »
i'm not even sure if i have a user id..all i've been able to do is register my email address and have a password with the main site. everytime i try to do so for the forum itself, it never works... would an email help?
