Author Topic: Noob looking for some help hooking up ledwiz to buttons.  (Read 1238 times)
briscos horse
  • Last login:May 19, 2013, 03:19:54 pm
« on: February 05, 2013, 02:49:48 pm »
I have a few BLUE CONVEX LED LIGHTED ARCADE PUSHBUTTONS
From Paradisearcade and I would like to connect hem to the Ledwiz.
I have looked all over and I have not been ble to find simple instructions.
The LEDs have 2 connectors.
Where do they go?
Does one go to the led wiz if so which one and where?
I have started trial and error but I don't want to fry the board or LED.
Thank you
Furry131
  • Last login:January 10, 2020, 10:55:54 am
Re: Noob looking for some help hooking up ledwiz to buttons.
« Reply #1 on: February 05, 2013, 02:52:50 pm »
http://groovygamegear.com/PDF/LEDWIZ_INSTALL.pdf
this should answer a bunch of your questions.
briscos horse
« Reply #2 on: February 05, 2013, 03:46:22 pm »
I used that doc to hook up the first led I tried and it did not light up.
Not sure if I need to running the software on the pc that is connected to it before trying to make it light?
RandyT
  • Last login:Yesterday at 12:12:44 pm
    • GroovyGameGear.com
« Reply #3 on: February 05, 2013, 04:00:32 pm »
Yes, that is what will be controlling the LED.  You can test the connection by holding a wire against the metal USB shell, and touching the terminal screw.  If it lights like that, then it will light for your software.
briscos horse
« Reply #4 on: February 06, 2013, 09:32:35 am »
I installed the led wiz software the led didnt light up. There are 2 wires coming from the led which on do i touch the usb shell with? Also which terminal screw do i use for the other one?
Furry131
« Reply #5 on: February 06, 2013, 09:36:06 am »
The Long one is the ground the short one with the resistor goes to the screws
briscos horse
« Reply #6 on: February 06, 2013, 09:54:18 am »
The buttons are self contained. I dont know what side the resistor is on.
Here are the buttons i bought http://www.paradisearcadeshop.com/en/led-pushbuttons/232-blue-led-convex-arcade-pushbutton.html
Furry131
« Reply #7 on: February 06, 2013, 11:32:33 am »
Well then, :dunno  I would think you need to contact armi0024 and ask him. He runs Paradise shop and should be able to help you.   You might be able to use the pictures from this page to figure out which one is the voltage source.
http://www.paradisearcadeshop.com/en/jamma-harnesses/66-ezswitch-off-led-button-control.html
and so I dont look anymore of a dumb ass I said ground in an earlier post but i meant the voltage source... it was early this morning.
RandyT
« Reply #8 on: February 06, 2013, 11:38:46 am »
No, you use a different piece of wire.  You are, as a test, jumping ground from the USB shell to the terminal on the LED-Wiz where your LED is connected.  This should cause the LED to light, if you have it connected properly.  If it lights when you do this, your software will also be able to light the button.
This is only a way to test your wiring, and you don't want to connect anything up this way in any solid fashion.
  • Last login:Today at 04:02:56 pm
« Reply #9 on: February 06, 2013, 11:40:45 pm »
Resistor is connected to the side that connects to 5v/12v when it lights up.
Paradise 12v LED shown below removed from holder. (upper right)
« Last Edit: February 07, 2013, 01:04:23 am by PL1 »
briscos horse
« Reply #10 on: February 07, 2013, 11:53:44 am »
Thanks everyone!
Part of the problem was the buttons with built in LEDs that I am using are 12v.
The led wiz driven by the USB is 5v.
I wired up a bunch of batteries equaling 12v and the led worked fine.
I know I could also get 12v from a power supply but I am using a laptop to run my machine so I will just order 5v LEDs and then everything will be fine.
Thanks again
« Reply #11 on: February 07, 2013, 12:03:47 pm »
The LED pic above is a 12v LED driven by USB 5v.
I've lit up 14 LED buttons and a trackball lighting circuit without a problem using USB 5v.
Bonus: This setup only draws ~81 mA. since I added an extra current limiting resistor.
« Last Edit: February 07, 2013, 12:19:01 pm by PL1 »
briscos horse
« Reply #12 on: February 07, 2013, 02:09:07 pm »
After seeing your post I just hooked up 6v batteries and it lit!!
When I get home after work I will try my ledwiz again.
briscos horse
« Reply #13 on: February 08, 2013, 09:36:27 am »
I finally got the leds working!
I wasn't able to hook them up to the banks on the led wiz because when i did they wouldnt light up. So for now only solid lights are working.
I guess more testing is needed or i need a voltmeter.
So far here is the progress:
