Author Topic: Saw this beauty on Reddit I was wondering..  (Read 1084 times)
willybeamish
  • Last login:December 22, 2014, 01:59:10 pm
« on: January 29, 2013, 12:00:27 pm »
How did they do the lighting on the coin door?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Currently rebuilding a PP cab and converting it to a mame cab..view the progress here http://forum.arcadecontrols.com/index.php/topic,122815.msg1305024.html#msg1305024
yaksplat
    • Random Projects
Re: Saw this beauty on Reddit I was wondering..
« Reply #1 on: January 29, 2013, 12:03:59 pm »
Cut out the panel.
Rout out the backside to desired thickness.
Add translucent plexi panel.
Stick eyes to the front.
Backlight with RGB leds at an appropriate distance.
http://yaksplat.wordpress.com
willybeamish
« Reply #2 on: January 29, 2013, 12:32:16 pm »
[size=78%]Add translucent plexi panel. [/size]
[size=78%]Backlight with RGB leds at an appropriate distance.[/size]
Did not know about the plexi planel thanks!! Also what do you guys use for Leds behind the plexi planel??
shponglefan
« Reply #3 on: January 29, 2013, 12:35:04 pm »
You can get coloured LED strips at various h/w stores these days (i.e. Lowes, Home Depot, etc).  Personally I like the Sylvania Mosaic strips since they do various colours and are remote controlled.
griffindodd
  • Last login:June 29, 2023, 02:43:19 pm
  • Builds Stuff
« Reply #4 on: January 29, 2013, 12:56:49 pm »
They captured a space invader and are holding him there with a magnetic ion beam available from Radio Shack
I drink and I know things.
lordnacho
« Reply #5 on: January 29, 2013, 03:44:51 pm »
That's what he gets for trying to poop on our space ships
willybeamish
« Reply #6 on: January 29, 2013, 03:45:39 pm »
I called and they were out of stock  :-[
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #7 on: January 31, 2013, 01:55:24 am »
I`d have got a thin sheet of plastic, some adhesive vinyl cut out the pattern on a plotter, and stuck it on, could have interchangable ones for a fraction of the price/work , stick a cheap little disco/novelty light behind it , cheap and nobody knows :) thinking of doing a few interchangable ones for my marquee
Hit something hard enough it should work, if it dont the result can always be called art :)
