Main > Everything Else
What PC temp app are you using?
<< < (2/3) > >>
lilshawn:
i read through that intel burn test...kinda funny actually. I'm typing this while i'm testing.
--- Quote ---Linpack by
Intel(R) is an extremely stressful program that will put even the most pow-
-erful X86/X64 CPU in the world at its knees. Load temp under Linpack will
be up to 22*C higher than the competing software Prime95.
i'm at 43 degrees and pretty stable... up and down a degree...but i also don't believe it's truly 100% loading the processor either. I notice some degradation of the computer, but 100% load should all but freeze the system. might be because i have a AMD processor and/or 32 bit OS.
brad808:
--- Quote from: lilshawn on January 30, 2013, 08:01:01 pm ---i read through that intel burn test...kinda funny actually. I'm typing this while i'm testing.
Just out of curiosity can you install coretemp and see what your temps are like under full load? 43 seems suspiciously low and I know some people have problems with speedfan properly reading temps depending on what sensors you have. Coretemp also has a percentage gage per core to show the load that particular core is being stressed with.
... If for whatever reason your cpu really does have a load temp of 43 degrees under stock voltage/ stock fan then you could probably do some pretty good overclocking with it!
Gray_Area:
@hypernova: yup, I got it from CNET and from that page you linked.
The above-shown reading was with my external fan disconnected (because it was so quiet without). According to Intel, the P4 Prescotts are supposed to be stable up to about 75 C.  I re-connected the fan, but turned it around so it is blowing out, and that seems three times quieter than pulling in. The temperature now idles around 35 C; a little higher right now with few tabs in a browser page, and Mala with background music on. Having a lot of tabs on two browser pages, and it may get up to 60 C.
lilshawn:
--- Quote from: brad808 on January 30, 2013, 08:35:52 pm ---
I'm liquid cooled.
EDIT: running AMD quad core FX black edition on an Asus M5A-78LM LX series mobo. 4GB ram and an older GT9500 videocard and 4 harddrives 500 watt power supply, which i should probably upgrade.
EDIT2: the temp you see in the display below is the temp of the coolant after flowing through the radiator.
EDIT3: i installed coretemp, but can't get it to work properly. I'm just getting random low temp readings 5-15 degrees. currently settled at around 7 Celsius. i'm poking through some settings, but nothing seems to work.
brad808:
Ah liquid cooling, yes that would explain it.
Sent from my Galaxy Nexus
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
