Author Topic: Recommendations on a USB trackball?  (Read 736 times)
Dcpmark
  • Last login:December 30, 2023, 11:28:10 pm
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
Re: Recommendations on a USB trackball?
« Reply #1 on: January 24, 2013, 06:12:40 pm »
Andy also has the U-Trak. I went with this since I have a wood panel and it mounted clean.
http://www.ultimarc.com/trackball.html
Don't really have anything to compare it too. But I don't have any complaints either.
Dcpmark
« Reply #2 on: January 24, 2013, 07:17:17 pm »
I was looking for advice to make my decision easier, not harder....  ;)
Ok, now I've got 3 to consider. It will either get retrofitted into a HotRod SE panel, or I might start from scratch and order a custom CP top from Jim and make it myself. Any thoughts?
Cynicaster
  • Last login:June 22, 2021, 12:12:55 pm
« Reply #3 on: January 25, 2013, 09:55:23 am »
I've also got the U-Trak and love it.  It was painless to mount on my MDF control panel, and on the net there's is a very nice step by step instruction (with pics) that somebody put together on how to install it.  I don't have the link, but it should be easy enough to find if you look for it.
I'm assuming the X-Arcade unit is the same one they put in the Tank Stick.  If so, it's worth noting that my brother has been using an X-Arcade Tank Stick for 3 years now and, while he is generally happy with it, whenever he plays on my cabinet he says "Man, I like your trackball SOOOOO much better than mine."
Dcpmark
« Reply #4 on: January 25, 2013, 01:22:52 pm »
That's some good info.....thanks!
mcseforsale
  • Last login:April 09, 2024, 03:07:41 pm
  • Creepy Mario Dude
« Reply #5 on: January 25, 2013, 02:56:53 pm »
The GGG 3" trackball is a clone of the Happ 3" and is of excellent quality.  With the required EZ-Wiz (get the no-solder one for +$2), it's still cheaper than a Happ Trackball.
I have both a vintage Happ with red board update and I just installed a new GGG on another machine and they are of equal quality.
Also, my trackball template works exactly perfect with the GGG as well as the Happ...
http://forum.arcadecontrols.com/index.php/topic,119081.0.html
AJ
