Author Topic: DIY panel saw?  (Read 42384 times)
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
DIY panel saw?
« on: January 20, 2013, 08:39:30 pm »
So, I've seen the CNC machines but its a big cost and a lot of time. The saw boards are great and all, but I just figured a few people on here must have built their own panel saw like you see in the big DIY stores? Something like the one below.
CoryBee
  • Last login:October 21, 2023, 07:12:25 pm
  • Bopity Boopy
Re: DIY panel saw?
« Reply #1 on: January 20, 2013, 08:50:24 pm »
Oh my. I have always wanted one of those
Nacimroc
Re: DIY panel saw?
« Reply #2 on: January 20, 2013, 08:55:12 pm »
It's got to be fairly cheap to make and stands up on wall at side of the garage so very handy for storage and cutting. I would love to build one with linear bearings running horizontally so that you move the saw left or right to the cut line instead of the board itself. $150-$200 all in for parts and a few hours to build? Stick a few cheap laser lights on it to give you guide lines and away you go.
CoryBee
  • Bopity Boopy
Re: DIY panel saw?
« Reply #3 on: January 20, 2013, 09:03:53 pm »
The one at my local Home Depot is able to cut along both axis. Up, down & Left, right.
TopJimmyCooks
Re: DIY panel saw?
« Reply #4 on: January 21, 2013, 10:26:16 am »
I would build one if I broke down plywood panels every day.  for occasional use, build a sacrificial plywood cutting table and use with a regular circular saw and a straightedge guide/sawboard.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: DIY panel saw?
« Reply #5 on: January 21, 2013, 10:34:53 am »
TopJimmy is pretty spot on there.  For me, I'm building a CNC machine but I also decided I wanted a panel saw and I got lucky.  A good friends dad works for Milwaukee Tool Company so I got a brand new panel saw for $300 with all the bells and whistles.
There's also a guy who will sell you kits to build your own:
http://panelsawsrus.com/products/
The only thing I'm concerned about when building your own would be to make sure all of your measurements are off and that there is no drift/wobble when the saw is on.
Nacimroc
Re: DIY panel saw?
« Reply #6 on: January 21, 2013, 12:45:43 pm »
All the ones I seen to buy were $1500+. That DIY one is fine, but for $300 and having to build most of it yourself anyway, I reckon you could build a much much better one. With a guide rail at top and bottom for the whole thing to move left/right to the line before cutting. This would allow you to cut sideways also without moving the sheet. Similar to a CNC.
I just figured there would be a few plans/projects done where people tried it.
BobA
  • What Me Worry?
Re: DIY panel saw?
« Reply #7 on: January 21, 2013, 12:59:55 pm »
Here is a site with downloadable plans.  Looks like a real heavy duty unit.  Uses a motor and belts not a separate circular saw.
http://woodgears.ca/reader/hector/panelsaw.html
Nacimroc
Re: DIY panel saw?
« Reply #8 on: January 21, 2013, 03:01:01 pm »
His one is very nice and well built. This guys was exactly what I had in mind. Looks cheap ish to build (not including the Festool  :o ) and does everything I would want. Skip to 4:48 for vertical cuts and switching cuts. (Would have to upgrade the way he measures and lines up the tool )
http://youtu.be/BAVJLgF9ejg?t=4m46s
