Author Topic: Rotating monitor retro fit.  (Read 5862 times)
rockyrocket
« on: January 20, 2013, 04:51:04 pm »
Not being able to control my envy for all these rotating monitor cab teases I decided I needed one.
My multi-emu / gameex cab was the best candidate so a retro fit was on.
I can not claim any original thought went into this at all, the hardware is an exact copy of griffindods build (thank you), I also only really have one shot of the build process sorry.
Anyway gameex has a really useful facility to send commands or launch apps/files both before and after loading games, so using AHK files was a dead simple way to activate the usb driver board.
Well everything just about fitted so here is a very bad quality video
« Last Edit: January 23, 2013, 11:36:45 am by rockyrocket »
  • Last login:October 31, 2025, 06:10:47 am
Re: Rotating monitor retro fit.
« Reply #1 on: January 20, 2013, 05:11:38 pm »
Looks awesome! :cheers:
It rocks having a full size screen for both orientations.
  • Last login:September 20, 2025, 07:17:24 am
« Reply #2 on: January 20, 2013, 06:33:57 pm »
What BadMouth said!
 :applaud: :applaud: :applaud:
mgb
  • North East, US
« Reply #3 on: January 21, 2013, 07:34:29 am »
Very nicely done.
what size is that monitor?
 It seems to me that often when a rotating monitor is done, the monitor is on the smaller size to allow for the movement
but this monitor seems to fill the cabinet very nicely.
Great Job!
TopJimmyCooks
« Reply #4 on: January 21, 2013, 09:21:29 am »
Good work.  Welcome to Arcade Manhood.
rockyrocket
« Reply #5 on: January 21, 2013, 09:40:57 am »
Think I will just reply with "thanks" for that one :D .
No thanks guys for the comments, the only really original part of the build from me was putting the limit switched on a adjustable post to fine tune the final screen position.
Speaking of screens its a 21" and was what was already in it  - and just about spun when decased.
One other thing of note is why the hell don`t the manufacturers have the real pivot point exactly center of the vesa mount?.
So I forgot I had some pics on my phone from the first fitting, as a rethink was needed to overcome some cable friction that was sorted with a cut out and a crafty twist and anchor.
« Reply #6 on: January 21, 2013, 10:04:58 am »
If I had mine to do over again, I'd use a 21-22" 4:3 LCD instead of a widescreen.
It looks much nicer without so much bezel around the monitor.
It supposed to be centered by weight, but manufacturers aren't required to adhere to that.
« Last Edit: January 21, 2013, 10:06:46 am by BadMouth »
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #7 on: January 21, 2013, 10:27:00 am »
Well done, looks great!  I love seeing Rotating Monitors!
darthpaul
  • Last login:Yesterday at 06:34:18 am
  • Join, It's your duty
« Reply #8 on: January 24, 2013, 07:17:54 pm »
Very well done, us rotating monitor guys have to stick together. ;D
Automated Cabinet
Nintendo Pi
PiCubed
Fursphere
  • Last login:October 26, 2025, 11:01:54 pm
« Reply #9 on: January 26, 2013, 10:18:49 pm »
Does anyone still make a 4:3 that big?  Everything seems to be widescreen now.  :(
rockyrocket
« Reply #10 on: January 27, 2013, 04:01:35 am »
Not that I am aware of, but hopefully someone will chime in with a link.
Mostly I just buy used ones on ebay, here in the UK we have  these pricey ones.
Fursphere
« Reply #11 on: January 27, 2013, 09:03:48 am »
For those prices I'd just buy a 27" widescreen - and for vertical games, you'd have almost the same screen size as a vertical 21"  :)
Fursphere
« Reply #12 on: March 16, 2013, 04:04:11 pm »
To the OP -
How wide is your cabinet?  (inside dimensions).  Mines is 24" wide, and I keep thinking I should rebuild it to be 26" to make room for a trackball.
rockyrocket
« Reply #13 on: March 17, 2013, 04:57:39 am »
To the OP -
60cm so thats just under 24"  you should be golden! ,it is a really tight fit under there but as you can see it all just about fits.
To get the room for the rotation I had to change the angle of the screen and drop the CP back and down a bit you can see from the pic that the monitor surround invades up behind the marquee and also down behind the CP a fair bit.
« Last Edit: March 17, 2013, 06:02:29 am by rockyrocket »
« Reply #14 on: March 17, 2013, 10:10:21 am »
Man, this looks great.  Well done!  :applaud:
Fursphere
« Reply #15 on: March 17, 2013, 10:52:50 am »
To the OP -
Awesome!  Thanks for info and pics!
