Main > Everything Else
Programmer outsources own job. Has lots of free time.
<< < (2/6) > >>
CheffoJeffo:
If the guy had a brain, he would have set up a local VPN for his guys in China to relay through ...
AtomSmasher:
--- Quote from: CheffoJeffo on January 17, 2013, 11:55:41 am ---If the guy had a brain, he would have set up a local VPN for his guys in China to relay through ...
That's what I was thinking.  He should of set up a proxy server from him home computer, so it would appear as though he was always connecting from his house.
lilshawn:
--- Quote from: brad808 on January 16, 2013, 11:06:28 am ---Sent from my Galaxy Nexus
I believe you have already started.
kahlid74:
--- Quote from: Xiaou2 on January 17, 2013, 12:33:49 am ---
 But even as I have worked in the computer field under much lesser positions, I knew they were able to log and track whatever I was doing, and read whatever email I was sending.  Did he really think nobody would notice the constant out of country traffic?  Nor ever check up on his PCs logs?
So there's a lot going on here, and I won't get into specifics but take it from a guy who runs data centers for your online banking sites, not every business does the same thing.  More often than not, businesses have holes everywhere that go un-patched/fixed.  The key here however is the "human condition".  This is where the real breakdown in network and security occurs.
lordnacho:
My theory is he started out small, had some Chinese developers write some code for him, which he tested and checked in as his own.  Wouldn't be hard to get them setup with a dev environment and test data.  Would be very hard to get caught doing this.  Then he got greedy and upped it to the next level, gave them direct access and sat back surfing(no one saw him doing this at work?)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
