Author Topic: Anyone know how to change this?  (Read 759 times)
Isaacle
  • Newbie
  • Last login:January 16, 2013, 02:33:15 am
« on: January 16, 2013, 02:33:15 am »
who can tell me? I've got what's supposed to be a dedicated 4 way joystick but it seems to be set to 8 way.
BobA
  • What Me Worry?
Re: Anyone know how to change this?
« Reply #1 on: January 16, 2013, 04:11:07 am »
If it is a dedicated 4 way it should not be able to work as an 8 way.   You may have the wrong stick.
  • Last login:May 05, 2024, 08:59:50 am
« Reply #2 on: January 16, 2013, 08:46:50 am »
You just move the thing.
  • Last login:April 27, 2024, 06:07:53 pm
« Reply #3 on: January 16, 2013, 08:57:47 am »
I dunno the name for it either, but flip the plastic square thing that hits the switches under the stick. You can move the stick to the diagonals but it should only hit 1 switch at a time.
« Reply #4 on: January 16, 2013, 09:20:36 am »
I was trying to be as vague the OP until he shares enough information to warrant a real answer.  >:D
The part you're thinking of is called the actuator, but flipping it only works on Happs & Happ knock-offs.
A sanwa JLW would require loosening and turning the restrictor plate.
A sanwa JLF would require turning the center part of the restrictor plate.
A seimitsu (and knock-offs) would require unscrewing and moving the plate on the bottom.
A lot of the old sticks had completely different actuators for 4 or 8 way operation.
BobA
  • What Me Worry?
« Reply #5 on: January 16, 2013, 03:21:47 pm »
You are going to have to tell us what dedicated 4 way or joystick model you are having problems with before anyone can help.
Unstupid
« Reply #6 on: January 16, 2013, 04:01:13 pm »
You mean the restrictor plate?
