Main > Main Forum
Head to Head bartop?
Pages: << < (5/6) > >>
CoryBee:
Best would be like unstupid mentioned, link two bartops together. I really like his neo-geo twins by the way, a neat read. Would be so much more awesome if both were fully functional by themselves as well as one turning into a controller and cloning the display for the other.
Dermee:
I would say it is possible to do. You could have one of the bartops (master) have a plug modded into the case which would output the display as well as have an input to a keyboard encoder within the master. The only problem would be the software side for the other bartop which you would have to putz with.
kuchta:
--- Quote from: CoryBee on December 20, 2012, 07:06:39 pm ---Best would be like unstupid mentioned, link two bartops together. I really like his neo-geo twins by the way, a neat read. Would be so much more awesome if both were fully functional by themselves as well as one turning into a controller and cloning the display for the other.
--- Quote from: Dermee on December 21, 2012, 02:40:00 pm ---I would say it is possible to do. You could have one of the bartops (master) have a plug modded into the case which would output the display as well as have an input to a keyboard encoder within the master. The only problem would be the software side for the other bartop which you would have to putz with.
My plan is to have 2 functioning bartops that can be joined together. I'm planning on using a KVM to switch the client bartop between usage modes, similar to the project below. The main difference is that I plan on using a video amplifier instead of trying to use dual monitors on a video card. I'm hoping that will make it easier to disconnect and reconnect the second bartop on the fly.
http://forum.arcadecontrols.com/index.php/topic,117295.0/all.html
Dermee:
Looks good kuchta. Have you noticed any lag or anything quirky?
kuchta:
I haven't even started anything yet. All I have now are the monitors. I'm hoping to get the ball rolling after the holidays at which point I'll start a project thread and hopefully have some answers. Input lag and encoder issues are my biggest concerns. I guess we'll see what happens!
Go to full version
