Main > Main Forum
Midway Arcade Power Convert 120v to 220v back to 120v - Need help
Pages: << < (3/3)
DaOld Man:
I dont think you will need an isolation transformer for that (but you do need to leave the one for the monitors).
Just cut the two black wires off the buck transformer and tie them together. If everything works, you can remove the buck transformer if you want. I dont see any reason to leave it in there, but I guess it doesnt hurt anything to leave it.
BrokenBuckets:
Good morning and again thanks for all the help.
I bypassed the buck transformer and turned it on. Machine powers up and I get video. Everything appears to be working.
Last question, I hope, how much, if any, noise should I get from the control board behind the monitor. There seems to be some clicking sound. My first machine so I don't know if that's normal or not.
Thanks again.
DaOld Man:
Sorry, I cant help you on that one. If it is coming from the monitor circuit board you may want to ask over in the monitor/video section.
Is it doing it on both monitors or just one?
WindDrake:
If both monitors are doing it, you're probably hearing deflection noise. That's normal.
BrokenBuckets:
Yes both monitors are doing it.
I got both machines powered up. Video on one starts fine but once the "game" starts the video just scrolls and I have nothing on the other monitor. Have sound and the game is running.
Guess now it's time to start reading up on video issues.
Thanks again for all the help getting the machines powered up.
Pages: << < (3/3)
Go to full version
