Author Topic: Simple removable control panels  (Read 15137 times)
spystyle
« on: December 15, 2012, 04:26:24 pm »
Hello from Maine :)
Well I haven't really been following arcade news, so if this has already been covered let me know.
I wanted to have removable control panels that were simple, so this is what I came up with :
1. Make a control panel that is slightly larger than the cabinet's outside diameter :
2. The overhang can be used to attach the "striker plate" part of the latch kit.
3. Each control panel has a keyboard encoder (and whatever other boards needed) attached to it. A USB keyboard encoder is ideal for removable control panels. USB can be unplugged while the computer is on, but PS2 must have the computer powered off to swap.
4. Blocks have to be in place so the control panel can't be pulled forward by the players :
And that's the basic concept I use to make simple removable control panels :
EDIT : Ultimately, I decided that the slot cut should be in the cabinet, rather than the control panel (as I did it). Cutting the slot in the control panel gives it a sort of 'finger' that can break off, LOL. It creates a fragile part.
If you need to add tension you can add a shim to each side. Here is one made from hardboard :
It's "wasteful" since each control panel uses it's own encoder board(s) - so there is an extra $25 fee per panel (at least). However, this results in a simpler swapping process.
EDIT : These days keyboard encoders can be bought for much less.
I order the latch kits here :
http://www.ebay.com/sch/m.html?_odkw=latch&_osacat=0&_from=R40&_armrs=1&_ssn=twistedquarter&_trksid=p2046732.m570.l1313&_nkw=latch+with+plate&_sacat=0
(I am not affiliated with the seller "TwistedQuarter" but he is a good seller, in my experience)
(alt) Here are some from Happ :
http://na.suzohapp.com/amusement/acesor/49005900.htm
I don't know if there is a Home Depot alternative for the "striker plate", since you only need 2 latches for the cabinet but every panel needs 2 striker plates.
Let me know what you think :)
Craig
p.s. I built this shelf to hold the control panels :
It's kind of hard to see the detail as the shelf and the two control panels are black, so I pushed the exposure. Anyway, it can be seen holding two control panels, the second one is not finished. The "striker plates" keep the control panels from moving horizontally in the shelf, and the wood keeps them from moving vertically. Right now it can hold three control panels, but holes are predrilled to add more horizontal pieces to hold up to six.
« Last Edit: May 02, 2018, 11:35:19 am by spystyle »
paigeoliver
  • Awesome face!
Re: Simple removable control panels (swappable, detachable)
« Reply #1 on: December 15, 2012, 05:26:50 pm »
Nice, when I tried that I made them slide in, but I am digging your method too.
Ultimately you might want to consider enclosing the bottoms of the control panels in an enclosure so they don't get damaged from being moved around. That was what kept happening with my slide in panels.
spystyle
« Reply #2 on: December 15, 2012, 06:58:43 pm »
That's a good idea :)
I'd like to see your panels too.
paigeoliver
  • Awesome face!
« Reply #3 on: December 15, 2012, 07:07:04 pm »
They are years gone at this point.
rCadeGaming
  • Last login:December 20, 2023, 09:16:09 pm
  • Just call me Rob!
« Reply #4 on: December 15, 2012, 07:08:32 pm »
Using a different encoder for every panel is wasteful, and there's no reason it would have to be any more complicated to keep the encoder on the cabinet side.  All of the wires between the encoder and the sticks/buttons/whatever could easily routed through a single connector.  A DB-25 or DB-37 would be great.
Also, how about holding the panel in magnetically for fast swapping?  Not too big of a magnet near the screen though, haha.
spystyle
« Reply #5 on: December 15, 2012, 07:54:49 pm »
I agree that using an encoder for each panel is a waste of $25 or more.
However, I am convinced it's the most simple. Especially if USB encoders are used. But I might try using a single encoder next time :)
Regardless, I hope I was able to contribute - if nothing else, a base concept others can improve upon.
As for magnets, hard drive magnets are extra strong ... that just might work :)
Maybe it's possible with "countersunk neodymium ring magnets"
eBay Link :
http://www.ebay.com/sch/i.html?_odkw=neodymium+ring+magnets&LH_BIN=1&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=countersunk+neodymium+ring+magnets&_sacat=0
Cheers,
Craig
« Last Edit: December 16, 2012, 08:43:00 pm by spystyle »
paigeoliver
  • Awesome face!
« Reply #6 on: December 15, 2012, 08:13:21 pm »
Strong magnets on the control panel would wreck havoc with a crt screen.
Cheers,
Craig
spystyle
« Reply #7 on: December 15, 2012, 09:46:53 pm »
Yeah truly, the magnets would have to be spaced or bucked properly.
In the meantime, I find this a very simple way to go :)
« Reply #8 on: December 16, 2012, 11:27:37 am »
For my swappable panels I have one (PS/2) IPAC in the cabinet. The panel controls connect with molex connectors.
Also I put the latches on the inside...bit harder to get to but only takes a minute or two to swap panels.
rCadeGaming
  • Just call me Rob!
« Reply #9 on: December 16, 2012, 11:38:46 am »
Sorry, but if you're still convinced of this, you're not grasping my or Minwah's post.  You're wasting your money.
spystyle
« Reply #10 on: December 16, 2012, 12:43:56 pm »
LOL, I didn't realize we were such a financially conservative bunch :)
I concede.
Post some pics of your solutions so we can correct this terrible thread !
  • Last login:April 30, 2024, 07:38:23 am
« Reply #11 on: December 16, 2012, 01:14:45 pm »
I concede.
 :duckhunt
Oh no, we're just here to criticize your work and let you know how wrong you are ;)
I haven't done swappable panels so good for you for tackling the project!  I do think you should take Paige's advice about adding some sort of component protection to the bottom.  I've seen tupperware used to great affect along those lines.
Check out Switchcade for an incredibly well done execution of the basic idea.
rCadeGaming
  • Just call me Rob!
« Reply #12 on: December 16, 2012, 01:32:13 pm »
Lol, sorry to be a dick, it just sounded as if you were being stubborn and illogical; and I'm all for spending top dollar on a cabinet, but that's just pissing away money for no gain.
Basically, you take all the wires between your buttons and your encoder, bundle them together, cut them in the middle, and wire them through a single connection for convenience.  Try one of these, it's a DB-25, meaning it can connect 25 wires:
http://www.digikey.com/product-detail/en/171-025-103L001/225ME-ND/858135
See those hollow things on the back?  They're called solder cups, and they're very convenient to solder to.  Here's the matching female connector:
http://www.digikey.com/product-detail/en/171-025-203L001/225FE-ND/858144
The screw holes on the ends can be used to mount them to a hole in a flat surface, or you can use a hood to make it a free hanging connection.  A hood just covers up the connections in the back of the D-sub and provides strain relief:
http://www.digikey.com/product-detail/en/86303639BLF/609-1426-ND/1001740
If you need to make more than 25 connections, you can use a DB-37:
http://www.digikey.com/product-detail/en/171-037-103L001/237ME-ND/858153
http://www.digikey.com/product-detail/en/171-037-203L001/237FE-ND/858162
http://www.digikey.com/product-detail/en/86303640BLF/609-1427-ND/1001741
Click my projects thread in my signature for an example (with pictures) of something I used a D-sub connector for.
walker_tr9
  • Last login:July 20, 2014, 08:51:15 am
  • Infinity is not a number!
« Reply #13 on: December 16, 2012, 02:34:05 pm »
Yes, but how much extra time is spent on wiring up this extra connector?  Can you do it in an hour?  If not, then I would spend the extra $25!
BTW: spystyle, can you post a bigger pic of the underside of the CP?  I want to see how the notches look from under there (the ones that mate with the cabinet).  Anyway, nice idea.
rCadeGaming
  • Just call me Rob!
« Reply #14 on: December 16, 2012, 02:37:56 pm »
Yes, you could do it in under an hour, the cab side connections only have to be done once, and we're talking an extra $25 per panel.
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #15 on: December 16, 2012, 03:47:31 pm »
I made a bunch of multpanels using 1 i-pac and network cables. Today, if I were doing it, I'd make my own Molex harnesses but still use the same philosophy. At $25 an encoder, it's way cheaper and simpler.
Xiaou2
  • NOM NOM NOM
« Reply #16 on: December 16, 2012, 05:18:49 pm »
May not be the most pretty solution, but an out-side mounted lock is a nice feature... as reaching into a coindoor to get to a latch is a real pain.
 Anyways, heres some ideas:
3 FOOT LONG ARCADE MACHINE JAMMA HARNESS EXTENSION CABLE - 56 PIN EDGE CONNECTOR
http://www.ebay.com/itm/3-FOOT-LONG-ARCADE-MACHINE-JAMMA-HARNESS-EXTENSION-CABLE-56-PIN-EDGE-CONNECTOR-/390437126308?pt=UK_Video_Games_Coin_Operated_MJ&hash=item5ae7ddc0a4
(cut it in half.  its already wired on both ends)
and
http://www.ebay.com/itm/50-PCS-P-N-CS51-098A1K0-ISA-SLOT-CONNECTOR-98-PINS-W-KINKED-/250971260503?pt=LH_DefaultDomain_0&hash=item3a6f0d8657
 98 pin ISA connector.   (for which you could probably grab some old ISA cards, and cut the ends off of the PCBs)
 Using several lan cables per panel would be a hassle and a pain.
 Molex connectors are not meant to be repeatedly plugged and unplugged.  They are often difficult to take apart, and they
often have pins that dont aligns well.  You also need special tools to put the things together, when those pins start failing.
 Printer cable connectors have a lot of pins, but are not easy to wire, because the pins are so close together... And wouldnt be as easy to get a good connector alignment when joining the male and female ends.  The connections are also very thin and frail.. and wouldnt hold up well to repeated use.
 Large trace Edge connectors are the easiest and most robust solution for something like this.
Same solution they used for the console cartridge based game systems.
« Last Edit: December 16, 2012, 08:06:52 pm by Xiaou2 »
spystyle
« Reply #17 on: December 16, 2012, 07:01:29 pm »
DB-25 and DB-37 explained :
If you need to make more than 25 connections, you can use a DB-37, which has 37 connected :
Thanks for the explanation, I'll try that on my next cab :)
Is that hot swappable in PS/2 and USB ?
Oh my, that is slick :)
...here's some ideas:
(cut it in half. it's already wired on both ends)
and 98 pin ISA connector.   (for which you could probably grab some old ISA cards, and cut the ends off of the PCBs)
often have pins that don't align well.  You also need special tools to put the things together, when those pins start failing.
Printer cable connectors have a lot of pins, but are not easy to wire, because the pins are so close together... And wouldn't be as easy to get a good connector alignment when joining the male and female ends.  The connections are also very thin and frail.. and wouldn't hold up well to repeated use.
Thanks for chiming in :)
« Last Edit: December 16, 2012, 09:11:19 pm by spystyle »
  • Last login:Today at 04:02:56 pm
« Reply #18 on: December 16, 2012, 08:37:49 pm »
Don't forget that D-sub connectors also come in the crimp version.
Pin extraction tool
spystyle
« Reply #19 on: December 16, 2012, 09:13:23 pm »
Thanks Scott :)
edekoning
  • Last login:November 10, 2022, 02:21:38 pm
« Reply #20 on: December 18, 2012, 02:39:22 am »
Well I would (and will) go for the 'OMG are you crazy' option and spend the 25 on an additional encoder. Off all the solutions presented here, USBs are by far the easiest to (un)plug. More importantly it can be done with one hand. All those other connection look like you need two hands to (un)plug (I might be wrong though). So when swapping the CP you can just hold it in one hand and use the other to unplug. If you need two hands, you first need to put the CP somewhere to free up your hands. And where will you put it, when its still attached.
When you have multiple encoders, led controllers, and what not, then it might be better to only have to disconnect one cable instead of 4/5 usb cables. One final thing to consider is if you have any buttons/leds that are not on the CP (e.g. coin door buttons). If so, you either need to buy a separate encoder/controller for them, or wire them to the CP using one of the non-USB options presented above.
« Reply #21 on: December 18, 2012, 04:39:46 am »
You have a bit of a point here, for my molex connectors I have to use two hands. However it is easy to sit the control panel in place but 'vertical' and hold in place while plugging in...it only takes a few seconds.
True, use a USB hub. I have a few panels which have mouse devices/joysticks etc.
No, if you go with the method of having the encoder permanently in the cabinet you just use that encoder. I have coin switches, start buttons and a pause (shift) switch connected all the time. Another good thing about this is that you only need one set of start buttons (if you have somewhere suitable to place them not on the control panel itself of course).
I suppose what it boils down to is how many control panels actually require a keyboard encoder?
« Reply #22 on: December 18, 2012, 05:25:26 am »
Since nobody else has mentioned it yet, you can get an AVR for a lot less than $25.
You can either solder wires directly to the AVR, use the 2.54mm screw terminals like Degenatrons did, or solder a 12-pin header to the board and use these or similar .1" header cables from Paradise.
EDIT:  Just found out that Degenatrons has some of his AVR encoders with terminals available.  This is not a KADE device but it will be compatible with the KADE Loader software when it is released early next year.  PM him if you're interested.
« Last Edit: December 18, 2012, 06:23:48 am by PL1 »
spystyle
« Reply #23 on: December 18, 2012, 12:27:09 pm »
Oh that's interesting :)
I saw the video here :
http://forum.arcadecontrols.com/index.php/topic,128745.msg1316035.html
And saw the price was only $7.00 here :
http://www.amazon.com/MINIMUS-AVR-ATMEL-AT90USB162-BOARD/dp/B00HCO6BFK/ref=pd_sim_sbs_t_1?ie=UTF8&refRID=1KJSE6FQRG1MDGYY4HRH
That's hilarious :)
It's fully programmable, that's fun. I guess it only has 20 inputs, but with a shift function it should still be able to support layouts as large as "Street Fighter" and still have many inputs left.
Here is what I worked out :
01) Player 1 up (shift available)
02) Player 1 down (shift available)
03) Player 1 left (shift available)
04) Player 1 right (shift available)
05) Player 1 button 1 (shifted ENTER)
06) Player 1 button 2 (shifted ESC)
07) Player 1 button 3 (shifted Player 1 coin)
08) Player 1 button 4 (config MAME to double as Player 1 start) (shift available)
09) Player 1 button 5 (shifted pause)
10) Player 1 button 6 (shifted load/save)
11) Player 2 up (shift available)
12) Player 2 down (shift available)
13) Player 2 left (shift available)
14) Player 2 right (shift available)
15) Player 2 button 1 (shifted TAB)
16) Player 2 button 2 (shifted F12)
17) Player 2 button 3 (shifted player 2 coin)
18) Player 2 button 4 (config MAME to double as player 2 start) (shift available)
19) Player 2 button 5 (shift available)
20) Player 2 button 6 (shift available)
(I've noticed you don't need a "Start button", as you can configure MAME so that a player's button doubles as "start")
Using all I could think of, there are still 11 inputs left.
That breaks the $10 price mark ? I remember when KeyWiz ECO2 broke the $20 price mark :)
Look at this wayback page from 2005 :
http://web.archive.org/web/20050307011918/http://www.groovygamegear.com/Page2.html
That is actually the encoder in the pics at the very top LOL, I had some left over :)
I still have one left.
OK, have fun!
Craig
« Last Edit: April 21, 2014, 12:38:56 pm by spystyle »
« Reply #24 on: December 18, 2012, 09:32:51 pm »
Wiring the shift functions for the AVR encoder firmware is covered on the resources page under "Extended Mode Wiring Diagram" here or you can skip the fancy wiring and use an encoder in the cab to handle your admin buttons, pinball flippers, etc.
spystyle
« Reply #25 on: December 18, 2012, 09:47:26 pm »
From the video, I thought we could use the loader program to make a custom layout.
Was my post completely incorrect ?
rCadeGaming
  • Just call me Rob!
« Reply #26 on: December 18, 2012, 10:43:55 pm »
I don't think most people would need that many connections for their cp, and a JAMMA connector is pretty bulky.  This the next part is clever though:
You could do this with any of the formats we've been talking about.  Just get a cable with a male and female end and cut it in half.
Guessing you mean D-sub connectors.  This isn't really true.  It's quite easy with the solder cups.  I've been using 22 gauge wire with DB-15 high density ("VGA") connectors without much problem.  It's even easier when you're using smaller wire or a more widely spaced connector like a DB-25 or 37.
No, not really.  Slides in pretty easily, and the connectors are trapezoid-shaped so you can't plug one end in upside down or something.
Now this part is reeaaaally off.  The hoods I linked to provide as much strain relief as anything.  There is no stress on the connections.  I've been constantly swapping around the same custom DB-15 controller cables on my sticks for 3 years now with no problems.
I wouldn't really recommend this.  Crimping those tiny connections and inserting them all in the housing can be a huge pain in the butt.  It's also not nearly as reliable as a single piece solid connector with solder cups.
Yeah if one side of the D-sub connector is secured in place (very easy to do), plugging and unplugging a D-sub with one hand is just as easy.
+1
I don't know much about these.  I'd like to know what effect these have in terms of lag and ghosting and such.
USB connections consist of four lines; one for power, one for ground, and two for data.  It's hard to believe nothing would be lost or delayed when compressing the signal of dozens of lines to be transmitted over just two.
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #27 on: December 18, 2012, 11:09:35 pm »
This guy lives not even 20 min from my place!!!  Is it just plug and play? I should pickup a few and try them out.
And saw the price was only $6.95 here :
http://www.foundmy.com/oscom/minimus-avr-usb-instock-p-396.html
That's hilarious :)
OK, have fun!
Craig
« Reply #28 on: December 19, 2012, 12:48:17 am »
The video describes the KADE which is currently in beta testing and due to be released early next year.
The KADE is basically an AVR encoder with improved firmware and additional hardware for those who aren't good at soldering.
Just think of the AVR as a motherboard, the AVR firmware as Win98, and the KADE firmware as WinXP -- you can use either OS with the MB, but the newer one will have more features.
Only true if you are using the wrong tool -- like vise grips -- to do the crimping.
With the right tool (ratcheting crimpers and correct die -- see pg. 74 here) you can make quick and accurate crimps that have rock solid mechanical and electrical connections.
If you claim otherwise, I suggest you talk to Nephasth about it -- his connector pron is the gold standard around here IMHO.
As a bonus, with the crimp version, you can remove/replace individual pins if you accidently damage them -- with the solder version, you need to replace the whole connector.
On this, we agree.
Why don't you ask Sharpfork how much lag there is?  AFAIK he hasn't encountered any during his extensive SHMUP gameplay testing on the KADE.
Ghosting is a MATRIX encoder (Hagstrom KE24, etc.) problem, so not sure why you brought that up in the context of a discrete input encoder. (AVR, KeyWiz, I-Pac, etc.)
If the USB connection causes lag, then your beloved MC Cthulhu must have the exact same problem, right.   ::)
IMNSHO thread-crapping when you admit not being familiar with the encoder in question is right up there with pissing into a public water fountain.   :tool:
"Better to remain silent and be thought a fool than to speak out and remove all doubt."
--Abraham Lincoln
« Reply #29 on: December 19, 2012, 02:20:46 am »
From Foundmy, you get the AVR, but no preprogrammed encoder firmware, screw terminals, or pin headers.
You need to program the firmware using directions and files here.  (This AVR will also work with the KADE loader program once it is released early next year.)
You'll need to solder individual wires, 2.54mm screw terminals, or .1" pin headers to connect your buttons.
Not exactly "plug and play" unless you get the pre-programmed ones with screw terminals from Degenatrons, but definitely a cool low cost encoder.  (I've got 4 of them to use in various standalone/portable controllers that I'm building.)
« Last Edit: December 19, 2012, 02:26:36 am by PL1 »
Xiaou2
  • NOM NOM NOM
« Reply #30 on: December 19, 2012, 04:01:28 am »
 I meant, that if you wanted to simply slide your control panel into place and have it work... rather than having to grab cables & connectors,  ... and plug & unplug them.
 A DSub / printer style connector is strong, but the wires attached are usually thin.  If the cable is bent and moved around often... internal wires can break...  and wires can detach from the pins.  This of course depends on how you set things up.
One static end which does not move... and one cable end... for example, would limit wear / damages to only the flexible cable
end.
 Still, you wouldnt be able to drop a control panel in place, or slide it in place, using a Dsub / DB connector... UNLESS, you were using a highly accurate channel guide system.  Even then, its a stretch, as the connectors have almost no forgiveness. (no play..  so need greater than MM accuracty alignments)
  A large edge connector however, has a reduced accuracy requirement, due to larger connections, and a connector that has some initial play, which funnels the cartridge/board into place, getting tighter as it enters.
 The connections are huge trace lines, on the 'moving' end, which helps keep wires from popping off, even after much abuse.
 Theres a reason why Game Consoles used this style of connector.   Imagine trying to pop in a Dsub ended cartridge repeatedly for your old game console.    Dsubs connectors are great for static application... such as locking them in place.
But for high rep use... they are not great for ease of connectivity.
 If your talking Monitor Dsubs... they often need to be screwed down to prevent them popping off over time.  Sometimes they are so tight, that its a real pain to try to get them together, or yank them apart.  Usually happens when the the thin metal outer shell has been dented from a simple 2ft drop to the floor.
 Printer / serial  based connectors are not much better.
 I dont think it matters how big the connector, nor the amount of connections.  Cost and ease of use, is usually the main factors for consideration.   You can always remove wires unused with ease.   The connectors themselves, will be hidden, (possibly even sunk-in... if you really want to get fancy)  so it does not even matter what they look like.
« Last Edit: December 19, 2012, 04:10:55 am by Xiaou2 »
spystyle
« Reply #31 on: December 19, 2012, 12:17:36 pm »
Thanks for all the excellent information fellas :)
rCadeGaming
  • Just call me Rob!
« Reply #32 on: December 19, 2012, 07:32:50 pm »
Yes, it will work great if done perfectly, but using solder cups is a bit more fool proof.  Crimping those small connections can be a chore, and the tiny little tabs that keep the crimp-on pins from backing out of the housings can get finicky.
I have experience with both methods and I'm just saying I'd recommend solder cups for someone starting out.  They're easier to work with and don't require buying a special tool, other than a simple soldering iron which you should have anyway in this hobby.  You also cannot argue that a crimped connection will be more reliable than a soldered one.
I haven't damaged any pins yet, and if I do these connectors are only a dollar or two.
You seem to have misread the tone of my comments on AVR encoders.  There's no need for so much hostility.
The KADE is claimed to have no lag, and I'm not disputing this.  However, that's not out yet, and I wasn't sure if some people are talking about use a generic AVR encoder, which wouldn't have the purpose written firmware and added hardware to ensure that it's suitable for game controls.  Notice how I just referenced AVR encoders in general, not the KADE specifically.
Just because that is something that's common with matrix encoders does not mean it's not possible to have a similar type of issue with other hardware.
It's not that simple.  If a USB connection has certain limitations, different hardware and firmware could tackle this differently and produce different results.  Notice that I said IF.  I never claimed anything about this in the first place, I just said I'd like to know.
Since the Cthulhu and the KADE are purpose-built for gaming, they've likely addressed whatever issues there may be as well as they could; but again, I wasn't comparing them, or even specifically questioning the KADE, just saying I'd like to know about AVR encoders in general.
--Abraham Lincoln
I really don't see how I was "thread-crapping."  I made no statement of fact about encoders.  I just said I'd like to know.  I didn't realize it was so inflammatory, and IMNSHO I think all the insults and hostility are completely uncalled for.  If you're going to crucify everyone who asks questions, we won't have much of a forum.
Come to think of it, I don't think I've even mentioned Cthulhu's in weeks, so I don't know why you brought that up.  It sounds like you've been waiting for quite a while for an excuse to attack me.  Whatever I did to deserve a vendetta against me, I apologize.  I guess.
Yeah, it's possible.  It's not really much of a danger though.  The same is going on in the cords for video game controllers, and they can stand up to quite a bit of abuse.  I wouldn't recommend going smaller than 24 gauge, but stranded wire is pretty tough.
Again, no.  Even with a free hanging cable, the hoods are designed to provide more than enough strain relief to prevent this.
The female side of a d-sub is slightly rounded to guide things in.  It's arguable.
True, game cartridges use PCB edge connectors because they allow so many pins, but the controller connectors are actually much more similar to d-subs, especially the Genesis/Megadrive and Atari.  Most just use plastic shells so they can use a propriety connector shape.
I don't bother with the locking screws on my custom A/V and controller d-sub cables anymore.  They don't pop off unless you give them a good yank.  They're not really that fragile either.
If we're talking about a free hanging cable, the d-subs would be much better due to bulk.  If we're talking about slide-in-and-lock system, which would be the slickest, I think both would work well.
« Reply #33 on: December 19, 2012, 07:48:33 pm »
I'm going to argue a couple things here. My Two-Headed Beast has thousands (yes, thousands) of crimped terminal pins, not a single wire has pulled out of any of those pins, even after numerous mating cycles. A set of crimpers that can crimp numerous different types of pins can be had for just as much as a cheap soldering iron ($30-$35), and is definitely a tool one should have in this hobby considering that all arcade machines utilize crimp connectors in their harnesses. I would not recommend soldering to someone just starting out (assuming they have no previous soldering experience), crimping pins on wires has a much more forgiving learning curve than soldering. If you've had problems with crimp terminal pins, you're doing it wrong.
rCadeGaming
  • Just call me Rob!
« Reply #34 on: December 19, 2012, 07:57:28 pm »
I'm just saying that in my experience I've done both, and one seemed like less of a hassle than the other to me.  Also, having a soldering iron and knowing how to use it pretty important in this hobby.
« Reply #35 on: December 20, 2012, 01:53:12 am »
I agree that knowing how to solder is an important skill -- as is crimping.
Ideally, people should learn both methods then use the one that works for the application at hand.
The main reason for the strong pushback was that the only AVR Encoder I've seen mentioned here is the one by Degenatrons that has expanded into the KADE project.
It looked like the issues you raised were aimed at this project.
Thought you knew the evolution of the KADE.   :dunno
I have no heartburn with questions being asked, but some questions contain potentially offensive implications.
The 9-11 "Truthers" are an example of how "just asking questions" can be offensive to an informed listener.
If no offense was intended, then let's consider the AVR question answered (Degenatrons' AVR Encoder and KADE work great, no problems with the concerns expressed) and get back to sharing holiday cheer.   :cheers:
« Last Edit: December 20, 2012, 04:13:47 am by PL1 »
edekoning
« Reply #36 on: December 20, 2012, 02:25:46 am »
I don't have a soldering iron, and never used one. I don't think I will be needing one either. I had also never crimped a wire until recently. I bought a semi-decent Knipex crimper for unshielded open-barrel f-type connectors. The few crimps I have made so far, have all been flawless and were so easy to do.
I looked up those d-sub connectors, and saw that they go up to 50 connections!. However, the crimp style versions are very expensive, especially those pins: 50 for 6,-. In the end, for me, its cheaper to buy a new encoder than it is to buy these d-sub crimp connectors and a pin extraction/insertion tool. The solder version will be a lot cheaper though, but then I would need to invest in a soldering station and spend time learning how to actually solder. In the end I will probably just go whatever route is easiest / most convenient. Even if that means spending 20,- more.
spystyle
« Reply #37 on: December 20, 2012, 01:06:35 pm »
Soldering is incredibly easy - if anyone wants a simple soldering tutorial with pics, let me know.
JMB
  • Last login:July 20, 2023, 07:29:22 pm
« Reply #38 on: December 20, 2012, 02:06:05 pm »
I'd love to see one if you are willing to do it. Thanks!
« Reply #39 on: December 20, 2012, 02:17:21 pm »
Plenty of tutorials on youtube.
